Remote Key does not lock / unlock doors after battery change
Old Feb 18, 2015 | 11:43 PM
  #31
Slider's Avatar
OK, you have a broken tab in your door. It was made of flimsy cast aluminum.
The fix is in this thread...
Door Part Failure
Getting the door open to be able to do the work is another issue. You'll probably have to get a towing company to come and break in. They can usually do it in a few seconds.
Old Feb 18, 2015 | 11:52 PM
  #32
Saadi996tt's Avatar
Saadi996tt is infamous around these parts
I have a buddy with a tow truck company so I'll have him come over and get the car open. Thanks for your help and I'll post as soon as I get the door taken apart.
Old Feb 19, 2015 | 12:25 PM
  #33
Saadi996tt's Avatar
I reconnected the battery and the key fob is working, will lock, unlock the doors and frunk. I tried to open the door manually with the key but nothing happens. I wonder if there could be a blown fuse that controls the door lock before I take the door apart??
Old Feb 19, 2015 | 04:19 PM
  #34
rmc1148's Avatar
I posted on the other site but neither door opening with key leads me to believe it has something to do with alarm. SLider I checked out your fix and was impressed= nice work.
Old Feb 20, 2015 | 12:56 AM
  #35
hashtagtrends's Avatar
hashtagtrends is infamous around these parts
This is so annoying! My friend had this happen to him a while back and local Porsche Service did not really know what caused it, this season this happened to my Turbo as well!
I cannot lock/unlock with a fob, have to unlock it with a key in door, jump in before alarm goes off and put a key into ignition. What is worse it only opens drivers door so my lady has to wait a bit till I am in, put the key into igntion and then pull the inside handle of her door.
Old Feb 20, 2015 | 05:39 AM
  #36
BLKMGK's Avatar
This happens to me only after the car has sat long enough for the electronics to "sleep". Does this happen to you always? What are you doing to set the alarm, one press or multiple when locking?
Old Feb 20, 2015 | 06:00 AM
  #37
'02996ttx50's Avatar
a "double click" of the fob puts the car to sleep instantly as the interior i/r sensor is de-activated. or so i am told. better to put the sucker to sleep nightly!
Old Feb 20, 2015 | 02:27 PM
  #38
Slider's Avatar
There is no electronics involved at all - that is what the door lock is for - to get you in the car with no power. See my earlier post - your aluminum connector is toast - no question.
Old Feb 20, 2015 | 02:30 PM
  #39
Slider's Avatar
These fobs have a built in "security" feature... If you activate the unlock while away from the car for 256 activations (30 seconds of sitting on your key), your fob is disabled until you unlock the car with the key and put it in the ignition. If activated 1024 times, the fob is toast and no one will get that sucker working again - ever.
Old Feb 20, 2015 | 11:13 PM
  #40
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
Just a note on my experience with my key fob not unlocking the door or opening the trunk/bonnet. There is a fuse in the security module under the drivers seat that will pop if your key fob starts to malfunction (my key fob internals were starting to have micro cracks from repeated use that started affecting the key fobs ability to transmit). If memory serves me correctly, it's a 15 amp micro-fuse. You need to remove the driver's seat to get to the security module and check to see if the fuse popped. I hope this helps.
Old Mar 9, 2015 | 03:24 PM
  #41
sparks's Avatar
sparks is infamous around these parts
Key stopped working on mine, red lite still flashed on key fob. Locked door with key, then unlocked and turned ignition to acc. . Key works fine now, Thanks
Old Mar 9, 2015 | 03:35 PM
  #42
Slider's Avatar
- perfect example of sitting on key in pocket for < 1024 activations. Good work!
Old Nov 12, 2016 | 02:10 PM
  #43
EuroZ06's Avatar
EuroZ06 is infamous around these parts
Need help... Just got my 2011 ctt, i live in montana so no dealers here.
Key lokcs/unlocks 50% of the time. Sometimes it works, sometimes it doesnt. I replaced the battery, did not solve the issue. I have no keyless entry option.
Can you please help with an advice? This really sucks. I cant pin point why it works sometimes and others it doesnt. I turned off my blutooth on the phone, disconnected my radar detector. Nothing helps. Ill try autozone's key tester, but its hard to catch when it doesnt work.
Old Nov 12, 2016 | 05:13 PM
  #44
jhbrennan's Avatar
You're asking the 996 forum...not sure if the system is the same as your 2011.
Old Nov 13, 2016 | 04:25 AM
  #45
fung0001's Avatar
fung0001 is infamous around these parts
Yes
I had not used it for a week
& the key can't unlock the car
Unlock using the key & start the car
It became mormal again
