Brookway R1000
Old May 1, 2010 | 01:05 AM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
Brookway R1000
i got it installed, very useful and helpful product, only thing is that it has an option for clearing out the DTC's ( ECU fault codes or errors) but it doesn't clear them out, i still have to plug in my laptop and use the Durametric to clear out all the error codes, anyone had any success on using this device to clear out the ECU error/fault codes?
Old May 1, 2010 | 01:09 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
clears the ones that have popped up on mine. codes to do with brake system/PSM when swapped to larger ones. but as i understand, some can't be reset, some can.
Old May 1, 2010 | 04:09 AM
jalmood's Avatar
Too bad that the ones that keep popping up with me are the ones that can't be reset by the Brookway, i bought it mainly for this reason.
Old May 1, 2010 | 06:34 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
??? My Brookway has cleared every code i have had, and some on friends cars to.
You sure your doing it right? Bit to be an ***, but i am just asking.
Old May 1, 2010 | 06:49 AM
jalmood's Avatar
sometimes even when there is codes it won't show them, it only shows up on my durametric, and if it appears in the brookway it won't clear out, is there a specific way or procedure to clear the codes out with the brookway?
dgreen78
Apr 21, 2015 06:04 PM
tvurt
Mar 28, 2011 09:50 AM
otb996
Oct 11, 2010 02:15 PM
Mad Ness
Jul 14, 2010 05:41 PM
John@SpeedTech
996 Turbo Vendor Classifieds
65
Apr 4, 2010 06:13 PM
