timng advance
timng advance
HI i have one 996 evoms GT 750 I boost has 1.5 bar i have recently to install a system WATER injection of coolingmist and i would like to know which degree of timing must I have 6500 rpm for a power maximun .THANK YOU
Your tuner needs to answer that question... not a board member...
Be careful and do not get on the car hard if you do not have a proper tune for the meth injection... you can hurt your motor....
2001 996TT 3.6L and stock ECU
well if your running only 121mph then something is very wrong... a flashed ecu will run those numbers... yet you say you have a 750 hp car? your off by 250 hp then...
you should be trapping at least 135 mph...
VP115 is good... the higher the octane the better...
If you have a 750 from Evoms and you trapped only 121 mph something is drastically wrong.... your solution is not the fuel or the meth.....
you need to call evoms and get that car to a evoms authorized dealer in canada...
I wish... I do speak Polish lol
adnanm3
Oct 25, 2016 08:38 AM
Oct 2, 2015 02:23 PM
