Flash with Stock Exhaust?
Old May 26, 2010 | 12:31 AM
J-996tt's Avatar
J-996tt is infamous around these parts
How would a basically stock (k&n drop in filter, diverter valves) 996tt run flashed, but with the stock ehaust still in place? I'm trying to decide which one to do first as funds are a little tight these days. Also my buddy just bought an 09 Raven R6 and wants to do some friendly roll races. How do you guys think that would go if the car was flashed?
Old May 26, 2010 | 01:24 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Go with the flash but also check Kens exhaust (PBK), it's the cheapest around the board.
I think that you will beat the motorcycle but at higher speeds
Old May 26, 2010 | 01:56 AM
you really need a good flash and a exhaust... one without the other is like a knife without a fork...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 26, 2010 | 08:26 AM
landjet's Avatar
I did the flash before the exhaust. You get a real nice power increase but leave some on the table until you open up the exhaust.
Old May 26, 2010 | 09:07 AM
John@SpeedTech's Avatar
Agree with landjet. I did the same thing and a flash alone is worthwhile. It's gets better when you add the exhaust.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old May 26, 2010 | 09:52 AM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Suppose you go this route. Do you need to retune for the exhaust? With my Old Subaru STI, any modification required a little tweaking.
Old May 26, 2010 | 11:09 AM
No, most off the shelf tunes are designed/written for an exhaust and if you don't have one on it's OK, as the slight difference does not require a specific tune. Then when you do put an exhaust on, it's all set...
2022 Cayenne White
Old May 26, 2010 | 11:11 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
John is 100% correct... You dont NEED retuned, however we do have specific file for stock exhaust (stage 1) vs aftermarket (stage 2).
Old May 26, 2010 | 12:23 PM
MBailey's Avatar
I ran a long time with a flash and stock exhaust. I think I got about 20 extra hp when I changed to a less restrictive exhaust. The real power comes when you change the turbos!
Old May 26, 2010 | 01:50 PM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
Good points - but some questions too.
I've been holding off on an exhaust as most all have drone. I just CANNOT have that resonance. I've had it in other cars, and it is just a huge buzz-kill.
I'm wondering if my 16G tune is specific for stock exhaust, or if I can just drop on a pipe and be good-to-go.
Car runs great as is, but some sweet sounds are welcome...
Old May 26, 2010 | 02:10 PM
jj,
You can "drop on a pipe" with your tune and you will experience an increase in performance.
Our 2.5 X-cellerator cross-flow is as close to a no resonance exhaust as you can get. There is virtually no drone, but in certain conditions there is slight drone that is barely noticeable. It is overwhelmingly offset by the performance increase and the fantastic exhaust note 99% of the time. Our 2.5 cross-flow is a blast to drive without the typical significant comfort downsides of an aftermarket exhaust. I am very drone sensitive and I love our 2.5 as a daily driver - it truly makes the car more enjoyable to drive.
2022 Cayenne White
Old May 26, 2010 | 04:52 PM
XLR82XS's Avatar
The SpeedTech exhausts are excellent and is the system I will be going with when the time comes. If you hear a 2.5 in person and STILL think it drones too much then you should look into Ken's modified OEM system. (PBK)
Old May 27, 2010 | 03:32 PM
lbmw's Avatar
lbmw is infamous around these parts
jj,
which exhaust (2.5 or 3.0) do you have in your car.....Louie
Old May 27, 2010 | 03:35 PM
lbmw's Avatar
i just order one from you but debating on getting the 2.5 since you have it in stock but i guess just wait for the 3.0 to get complete and should just pass up on the exhaust for the car show...can't wait to get and next thing will be the EPL flash..
Old May 27, 2010 | 03:40 PM
Exhausts are a must if your doing a flash... the car comes alive big time...
usually a 2.5" is fine... 3" like we do are great but also are louder. Thus a combination of both usually does the job... also ID of mufflers, type of packing material, inner cores all matter when it comes to sound and performance...
Uploaded with ImageShack.us
9.66
click to view
