Blew coolant line or something tonight.
did you guys actually weld this part or braise it?
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
I did it when I was "already there" for other work. If you had this done by itself it would cost about 2K just for the labor to remove and replace it. The welding is nothing...
If you don't have an issue with it, you are better off waiting until you do. If the motor is out for something else, that would be the time to do it. That's what I did....took advantage of the motor being out and welded it up, so I don't have to worry about this particular failure again.
2022 Cayenne White
2022 Cayenne White
Have your shop remove the part being held in the picture below and weld the inlet and outlet fittings to the main body. If you look closely, you will note the fitting is missing on the side closest to view. This is the side that became loose and suddenly disconnected causing a massive loss of coolant in seconds.
2022 Cayenne White
2022 Cayenne White
Hmm, Is that possible?
for simplicity: take an aluminum pipe, cut it in half, and glue it back together. There is an adhesive that can do this and be stronger than original? A proper weld will be very close to original strength.
Last edited by Talisman013; Sep 4, 2010 at 11:57 PM. Reason: Didnt want to sound like a arse.
Also- did you weld in the original fittings, or did you buy new ones from the "shop in Oregon?"
Glueing it together in a Girth Weld fashion no i wouldnt say so. but if you overlap two metals there plenty of ways to make it stay together 3M has some really cool stuff in their not published catalog alot of aerospace companies use.
now in this situation id prefer to braise the connection as it will be simpler then trying to tig the conenction.
i was simply replying about glue/adhesive is already everywhere on cars not anything new.
Bottom line is the glue fails over time.. To braze this item after it has been glue will be tough. All the glue will need to be removed. You can how ever clean it the best you can and tig it over. Fixed forever! Why try to reinvent the wheel? The glue is cheaper and has less an impact on overall cost of production. A tig welder, be it a person or a robot, the equipment and gases, increase in energy consumption, and so on! The glue gets the car out of the warranty range so why do more then that?
Tim
Tim
Tim
Tim
Are there any additional glued fittings on the motor that should be welded other than on this part?
2022 Cayenne White
2022 Cayenne White
Update: Almost 3 years later, still holding strong. I kind of forgot about this. If you are in this scenario, keep in mind, JB weld is MUCH stronger than the cheap glue they use at the factory so at the very least, you are better off then when the car was new. As long as you clean, scuff, and dry the surface before JB welding, you are golden.
I would concur on JB weld working well. When my second fitting blew, it was accessable from the enging bay, so we JB welded it back in place and I drove the car for over a year like that before I had to have the motor out, which is when I decided to weld them...
2022 Cayenne White
2022 Cayenne White
c'mon man, that pun was fully intended ..ha
+10 on jbweld. keeping parts of my house together. why not coolant lines. i just now covered a rocker panel drip on my old bike with the stuff. miracle mix.
