What does this actually do?
Old Jun 2, 2010 | 10:24 PM
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
Hey guys, I am in the process of rerouting my F-hose and cleaning up that area a little bit.. Here is where I am stuck at the moment.
THIS PHOTO CONSIST OF THE F-HOSE AND V-HOSE UNDERNEATH..
Q: Take note of circled insert for "number 1"
THIS IS A PHOTO OF WHAT PLUGS INTO THE V-HOSE..also known as "number1"
Q: What is the purpose of this line? Is it vacuum?
THIS IS A PHOTO OF WHERE THE OTHER END OF "number 1" line plugs into..
Q: Purpose of this? If its vacuum, is there a preference to what must be plugged into there?
THIS IS A PHOTO OF WHAT IS ATTACHED TO THE V-HOSE
Q: What is the purpose of the grey box? Is it a solenoid? There are 3 vacuum lines coming out of it I imagine. Top goes to this circular thing, side goes to the top of the Bosches before and the bottom is connected elsewhere. What is the true purpose of this grey box?
Q: Lastly, What is removable and also interchangeable/sharable lines? Thanks for reading through the post. I know with knowledge of how this works I will be able to come up with a solution. Thanks
Old Jun 2, 2010 | 10:59 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
The grey box is the boost solenoid, number 1 is where it vents back into the intake stream when it is active. Other than checking for leaks, I wouldn't mess with it.
Old Jun 2, 2010 | 11:11 PM
enoyskt's Avatar
Thank you for the explanation of that. Does anyone know where the line to the right of the grey solenoid goes to? and what it does?
Old Jun 3, 2010 | 01:12 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
