Top 5 things to help spool times - need your opinions!
Old Jun 9, 2010 | 11:10 AM
MBailey's Avatar
Like others said spool is dependant on airflow. You need as free a flow as possible without making too much dead space for the turbo to pressurize. Its a fine line in how much is good and how much is too much after the turbo (ie too big ICs).
So everything from the airfilter/intake to the exhaust/cats can help or hurt spool (and power). So choose carefully!!
Old Jun 9, 2010 | 11:19 AM
Romans 1:16's Avatar
Romans 1:16 is just really niceRomans 1:16 is just really niceRomans 1:16 is just really niceRomans 1:16 is just really nice
Thanks for all the good info!
Budget-wise I have to stay with the K24/18g's (that do have upgraded springs/wg's) but I think I have a path forward especially since the motor is already out of the car:
1) already have a free flowing exhaust with 100 cell cats (and heavy soled shoes )
so that leaves:
2) turbo inlet piping
3) headers
4) upgraded hoses
5) upgraded IC's
I also have the upgraded AP throttle body (uninstalled), but am thinking about returning as I have ready/heard mixed reviews.
Does anyone have any opinions on this with regard only to spooling time and not hp?
Old Jun 9, 2010 | 11:28 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Getting good info here,niiice
Old Jun 9, 2010 | 07:24 PM
John@SpeedTech's Avatar
Romans,
Upgrading to an OEM style silicon hose will not help you at all, however, upgrading to a 2 1/2" silicon hose and larger Y-Pipe like ours below eliminates all OEM bottlenecks and will help you attain your goals...we offer a bundle of EVO inlet ducts, our hi-flow 2.5" Y-Pipe/hose kit and EVO IC's with matching 2 1/2" hi-flow connections for our silicon hose, which is perfect for what you desire...the Y-pipe is available in either OEM or larger throttle body sizes (75mm TB opening pictured), if you upgrade the TB.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jun 9, 2010 | 07:48 PM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
The AP TB/Plenum moved my spool a noticeable amount, perhaps 150 -200 rpm lower. It is a DIY but takes some time, to fit and pressure test.
I already have bigger IC's and the normal bolt - ons as well.
Old Jun 9, 2010 | 09:28 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
while on this topic, while freeing restrictive flow would help, doesn't making the airways larger also lengthen pressure build up and create lag? ie commonly understood increasing size of IC's will create lag. Not sure how this applies to this car regarding lag.
Old Jun 9, 2010 | 09:32 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
https://www.6speedonline.com/forums/...rs-tune-2.html
lets blow this myth out of the water! reduction in pressure drop >>>>>>>>> time it takes to fill the slight change in volume.
Old Jun 9, 2010 | 09:40 PM
there is more to it then that... a stock endtank inlet is only 1.8" ID... when we do the big ICs at 2.5" we increase the ID by .5".... thus most cars that do run big ICs also do 2.5" hard piping... it all helps...
this is what Im talking about...
Uploaded with ImageShack.us
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
cinellipro
Dec 20, 2017 07:12 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 06:34 AM
Nissan GTR
Aug 19, 2015 02:11 PM
