Brockway stays on
Old Jun 11, 2010 | 09:37 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
Originally Posted by Zeroh
simply fantastic product and every turbo owner should have one !!
+1 i agree. too bad no pin out for oil temp on this car tho.
Old Jun 11, 2010 | 11:39 PM
Turbo Fanatic's Avatar
It's not a battery drain issue. It seems to draw next to nothing.
I just wasn't a fan of the display staying on and attracting attention.
I agree that it's a great product as well.
Originally Posted by pumalex
how much energy is that taking? Is it bad for the battery? haven't installed mine yet.
Old Jun 12, 2010 | 08:18 AM
911 RV's Avatar
911 RV is infamous around these parts
Ari, mine turns off within 30 seconds only when I remove the ignition key and depress the remote lock to lock the doors. If I turn motor off and leave key in, It stays on a while as well as the dash lights.
Is this the same for you.
Old Jun 14, 2010 | 07:16 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
From what I read on there web site when the car is turned off it is actually reading the ECU? and storing its information, so could it possibly be with everybody different tunes it takes longer than others to read??? Mine usually takes 15 - 20 minutes. Doesn't bother me, When I park the car for several days I usually unplug it to be safe. FWIW Also anybody here running stock IC's with tune? curious what IAT your running normal conditions say around town?
Old Jun 14, 2010 | 02:25 PM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
any one tried to erase the ECU fault memory with the brockway, mine doesn't store any error codes, but when i plug in my durametric i notice that there is a couple of fault codes which are not detected/stored by the brockway.
Old Jun 14, 2010 | 09:35 PM
John H.'s Avatar
John H. has a spectacular aura aboutJohn H. has a spectacular aura aboutJohn H. has a spectacular aura about
I'm failing to see the wonderfulness of the Brockway unit.
-The boost gauge isn't useful being digital, small readout, and usually mounted out of line of sight. Why not get a real boost gauge you can actually see with peak hold/memory playback/set warnings?
-The A/F readout is worthless since it's using the stock O2 sensors. You need a wideband unit to give an actual A/F. Once again, digital, small readout, and usually mounted out of line of sight. No pre-programmed A/F lean warning? Why not get an Innovate or AEM with an actual programable gauge?
I could continue, but all the other features including the ones above are neutered versions of a run of the mill OBD2 Port program which can be very useful (and work wirelessly on your iPhone). I keep seeing the advert for one of them on this forum.
John H
Old Jun 14, 2010 | 09:42 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
John H
waiting for the reply to this useful post......
Old Jun 15, 2010 | 02:52 AM
Mad Ness's Avatar
brockway's nice cos it detects codes, and allows some codes to be reset on the spot. Can be mounted on top din. Bunch of other parameters which are useful like IAT. ECT is more accurate than the dash gauge. plus it matches interior nicely.
think for most mild modded cars, this is a nice addition.
valid point on boost read out, i installed an analogue seperately.
aren't these cars equiped stock with wideband sensors?
between innovate and AEM, AEM, much easier to install, no periodic calibration, and cumbersome interface.
pwdrhound
11
Nov 25, 2015 01:18 AM
flewis763
Oct 4, 2015 04:14 PM
pwdrhound
Sep 25, 2015 05:25 PM
