996tt X50 VS Dodge Ram SRT10 SC Who wins
Old Jun 15, 2010 | 06:09 PM
Divexxtreme's Avatar
He's only making 608 rwhp? The only one I found that went 10's was making 860+ rwhp. The ones in the 600 rwhp range are in the low 12's.
From a dig in the 1/4 mile, it'd be close. But in anything longer than a 1/4 mile, or a roll-on race, you'll kill him.
http://www.dragtimes.com/results.php...arch+DragTimes
Old Jun 15, 2010 | 06:17 PM
Prche951's Avatar
here is a vid of a hennesey 650r. 12.4 at 116 mph, about the same as a stock turbo. if you have a tune and exhaust, dv's etc, you will win.
http://www.youtube.com/watch?v=cLih_...eature=related
Old Jun 15, 2010 | 06:40 PM
germeezy1's Avatar
germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !
That is a regular cab which should be faster, I would also imagine that being rated at 650 flywheel to be a bit less than 608 rwhp. As has already been said this truck probably has a built trans and a spool as well as a stall I would imagine.
Old Jun 15, 2010 | 07:14 PM
Prche951's Avatar
true, however, I seriously doubt a 600 rwhp 7000lb truck will do better than high 11's. If it has gearing, built trans and is topping out at 130, maybe low/mid 11's, but from a roll no way. If the truck is totally gutted then it may do it.
Old Jun 15, 2010 | 07:20 PM
germeezy1's Avatar
5600 lbs ....is hardly 7000 lbs....where did that number come from?
Old Jun 15, 2010 | 07:22 PM
germeezy1's Avatar
Also one thing to keep in mind is that is 608 rwhp through a built auto that is sucking up alot of power on the dyno.....meaning this truck probably has an ET better than what it might show on the dyno or in trap speed.
Old Jun 15, 2010 | 07:26 PM
The link I posted earlier (see below) shows the rwhp, and relative E.T. and Trap Speeds for some of these trucks:
A supercharged '04 with 628 rwhp ran 12.1 @ 117 on M&H's with 4.10's.
Old Jun 15, 2010 | 07:44 PM
rh888888's Avatar
rh888888 is infamous around these partsrh888888 is infamous around these parts
looks like the Quad Cab runs a 14.3 @ 99 mph stock. The fastest Super Charged one on Dragtimes (no NOS) was 12.1 at 117 but that was not a quad cab. I think this may be closer than I thought.
Old Jun 15, 2010 | 08:51 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
It's all fun and games until you run into this guy...
http://www.youtube.com/watch?v=QXY_R...eature=related
Old Jun 15, 2010 | 09:19 PM
WearyMicrobe's Avatar
WearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond repute
There are more then a few on VTCA that are in the high tens low 11's in QC. They respond well to N02 and Boost.
Old Jun 15, 2010 | 10:02 PM
Prche951's Avatar
that is truly not bad for a cinder block.
Also, the cinder block will get slower and slower the higher the speeds are, so to extract another 10 mph out of it will take loads of power.
Old Jun 16, 2010 | 02:20 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
don't forget to take a video
Old Jun 16, 2010 | 07:54 PM
rh888888's Avatar
This is the truck I will be racing. Belive it or not but he set off the fire alarm in the building in this picture and they evacuated it.
Old Jun 16, 2010 | 08:21 PM
MBailey's Avatar
Sorry no pics...
Old Jun 16, 2010 | 10:14 PM
Turbo Fanatic's Avatar
That V10 truck has the longest gearing. You'll need a good launch and a good shift to 2nd just so he can go through 1st gear.. That said, I'm betting you win.
