EVOMS GT2 Slave Conversion Question
Old Jun 25, 2010 | 07:17 AM
Yikes's Avatar
Yikes is infamous around these parts
If you swap out the OEM clutch slave/accumulator for the EVOMS GT2 conversion kit do you need to also change out the power steering pump and reservoir for the GT2 spec parts?
Old Jun 25, 2010 | 08:37 AM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
not necessary
Old Jun 25, 2010 | 09:45 AM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
Same answer as above with a little more detail. The Ps pump has a little slave pump that runs the clutch hydraulics and that pump is run by a small coupler that is easily removed when you go to the slave delete, then the lines from the slave pump are capped off and you are good to go. The installation guide covers this in great detail with good pictures and it all works fine.
BTW, highly recommended mod. Much better feel, and fewer things to break in the future.
SharkyShark20
Sep 19, 2015 09:54 PM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
