Help Quick! can't find coolant drain plug! 2001 TT
Old Jun 27, 2010 | 03:47 PM
Keithbeats's Avatar
Keithbeats is a splendid one to beholdKeithbeats is a splendid one to beholdKeithbeats is a splendid one to beholdKeithbeats is a splendid one to beholdKeithbeats is a splendid one to beholdKeithbeats is a splendid one to beholdKeithbeats is a splendid one to behold
Question Help Quick! can't find coolant drain plug! 2001 TT
I cannot find where the drain plug is for the coolant! Can anyone tell me where to find on a 2001 TT? TIA!
Old Jun 27, 2010 | 04:26 PM
jpflip's Avatar
This is the plug mention in the repair manual. Is it the one you could not found?
Never done it but looks like the two possible points....
ID:	127029   Click image for larger version
Old Jun 27, 2010 | 05:16 PM
Keithbeats's Avatar
Thanks, that's what I guessed. I loosened it and coolant came out, so I went with it.
There are two, drivers side (which I removed) and passenger. I just went with one so far.
This job is a beezy.
Old Jun 27, 2010 | 05:30 PM
jpflip's Avatar
Remember, best way to fill and bleed the system is using a Radkitusa from snap-on or similar. And if you don't have this kit you can always drive for a few days with the valve open on the expansion tank and monitor the level..... Good luck!
Old Jun 27, 2010 | 06:26 PM
Keithbeats's Avatar
Okay, if anyone can help me here. Here's what has happened so far in order:
1. Jacked up the car
2. placed jack stands
3. placed jack under engine
4. drained coolant
5. removed IC hoses on Y-Pipe
6. lowered engine with engine screws under car
7. removed hoses on Coolant Expansion tank
Now I'm stuck. I can't seem to remove the coolant tank.
I unscrewed the nut attached to the cars body.
I can't pull it out far enough to remove it from the track it's attached to.
Anyone with experience, please help. I appreciate any info on this.
Best,
Keith
Old Jun 28, 2010 | 03:49 AM
jpflip's Avatar
Just in case you don't have the repair manual....
Old Jun 28, 2010 | 06:39 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
rep and rep for JP!!! LONG LIVE THE DOC!!
Old Jun 28, 2010 | 06:53 AM
Keithbeats's Avatar
Thank you, Thank you!!! I am so happy right now, I would hug you.
I'll be in the garage all day today working on this one!
Best,
Keith!
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 27, 2015 08:50 AM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
JMon
Aug 21, 2015 08:20 AM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
