Multiple issues: ABS/PSM, ignition ring, etc.
Old Jul 14, 2010 | 12:57 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Originally Posted by kwei
Ok update time. I went through the process of cleaning my MAF using Adam699's writeup located here. Pretty straight forward stuff. My voltage checks were within spec before and after cleaning, car ran smooth before, still runs smooth. I need to put some miles on it to see if I can trigger the ABS/PSM warnings while moving though, as I have only been able to put about 10 miles on the car today after the cleaning. That being said, my Durametric is triggering them every time I have it access the ABS module. I get the warnings on the dash, but Durametric software is not putting up any codes. Shutting off the car and restarting it will clear them...until I check that module under Durametric again. I have seen this with both version 5.x and 6.x. I'm thinking I've done my due diligence as far as my capabilities and it might be time to have it looked at by a professional. I'll probably see if driving it around in the next few days gives me any codes, and go from there. Any further thoughts are appreciated, will keep you guys posted. Thanks again.
Justin
Hi Justin,
Just a quick one, My Durametric does the same (on my car and the others that have been on it)for the ABS module. It must be one of thoses things not to worry about using it.
Frank.
Old Jul 14, 2010 | 12:27 PM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Originally Posted by Sunnyside
Hi Justin,
Frank.
Frank, good to know. I'll stick to my driving tests and see where it goes from here then. Muchas gracias!
Justin
Old Sep 6, 2010 | 08:28 PM
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
I have this PSM/ABS problem too after putting on 997tt wheels and I'm thinking its my tire sizes (I have 235/35/19 PS2's and 315/25/19 Nitto Invos). I have already reset the steering angle sensor, and that did not fix it. My tire sizes are 3/12'' off, which is supposed to be in spec, but still perhaps off enough. Further, my rears are nearly new and the fronts are perhaps 70% good, so that could affect the diameter even more. This diameter difference is what I'm thinking sets off my PSM around turns, as it probably screws up rotation enough to make the PSM think the wheels are slipping when they are not. I only have PSM go off around a turn at moderate + speed, not in a straight line.
Please add if you have any updates. I'm searching the archives here. I need to fix this PSM problem, it's driving me nuts and is actually quite dangerous.
Old Sep 30, 2010 | 01:51 PM
kwei's Avatar
Update for you, I am still working on my own solution right now. Very annoying problem, probably going to have to throw some more $ at it and I am just waiting for some extra change to do that. I've tried cleaning my maf, replacing my tires (went to stock sizes front and back), alignment. What I have not tried yet but will be consulting my mech about: wiring harness replacement, PSM control module replacement, cleaning the throttle body. The last one I was informed worked for another member and apparently was relatively low cost.
Justin
Old Sep 30, 2010 | 02:23 PM
Justin
Hi Justin,
You say you have cleaned the MAF, but have you tried a new one...???
Could be Duff and cleaning is no use!!
Using your Durametric you can log the MAF readings first. It should be about 30 to 50 ish on idle and should go up as you rev the engine. Try making a log and post it on here. There are plenty of Durametric Techno's who will help.
Frank
Old Sep 30, 2010 | 09:03 PM
kwei's Avatar
Hi Justin,
Frank
Hey Frank, thanks for keeping on top, yea I am dragging my feet about getting this problem resolved. I should have been more clear, I did plug my durametric in and watch my maf readings as I increased engine RPMs. It was a one time thing, so I am not sure what guide I used to do it. I'll give it another run to double check. Thanks again.
Justin
Old Feb 26, 2011 | 02:32 PM
kwei's Avatar
Ok time to add some closure to this thread. I had my car in the shop last month for a issue not mentioned here (leaking pentosin). I had my brake light sensor replaced. Since then I have had no re occurrence of the ABS/PSM error. Why I was not getting any messages or warnings about the brake light sensor at the time of post, who knows, but I am glad the problem was found and at this point appears to be resolved. This also ties into the other issues I listed above. The fast blinking light was fixed by cleaning the contact points on the headlight, and I think I have already mentioned that the ignition switch was replaced and it fixed issues 1 and 2. Thanks everyone who lent some input and advice!
Justin
Old Feb 26, 2011 | 03:33 PM
jpflip's Avatar
Justin
When you are talking about the brake light sensor do you mean the brake switcj mention in this thread? http://www.renntech.org/forums/index...28#entry196428
Old Feb 26, 2011 | 04:57 PM
MikeR397's Avatar
Justin
I will keep this in mind. I think the problem is still there for aggressive driving for me. Brake light sensor, really?
Old Feb 26, 2011 | 06:16 PM
tphss's Avatar
tphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of light
The ABS/PSM lights usually go off together. I guess because maybe when the ABS has a problem the PSM won't wort properly?
A couple of months ago I had the ABS/PSM lights turn on together on my car right after I started up the engine, this happened every time along with an error appearing, I took it to the dealer and it was a faulty MAF sensor. I would check that first along with any other thing you might do.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
Texas1
Sep 20, 2015 09:12 AM
BLKMGK
Sep 19, 2015 03:51 PM
Suds26
Sep 2, 2015 01:33 PM
