Misfires
Old Jun 30, 2010 | 07:35 PM
bsprad's Avatar
bsprad is infamous around these parts
To those of you who had the same problem- did you replace plugs with stock or others to solve the issue?
Old Jun 30, 2010 | 07:38 PM
ttboost's Avatar
Basically, if your car is stock, run stock plugs. If your car is flashed (or more), run the plugs your tuner recommends.
Old Jun 30, 2010 | 07:45 PM
bsprad's Avatar
Tuner recommends stock plugs. I'm having them installed tomorrow.
Old Jun 30, 2010 | 07:51 PM
griggsat's Avatar
griggsat is infamous around these parts
It was suggested by my tuner to run a colder plug after flashing (and getting misfires). Even if not 100% necessary now, with a few more mods I would definitely need them. From what I understand a colder plug cannot hurt your engine, but not running a colder one when you should can hurt your engine.
I went with Denso IK22's.
Old Jul 1, 2010 | 12:56 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Just my input.
There is always the exception to the rule.
Run a cold plug and don't get it into its heat range and it will foul up, make carbon and cause very poor starting, poor slow running/idle and high power misfires.
You have got to get the correct heat range for your individual application.
But yes, if you have a heavily modded car its best to have a cooler plug as they will self clean. So long as you dont drive like your Granny.lol
Frank.
Old Jul 4, 2010 | 01:36 PM
bsprad's Avatar
I ended up getting new stock plugs and coil packs installed and the car now runs great. What an amazing difference. I'm now holding 1.3bar easily and the car feels like new. It's also idling and running smoother overall.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
whtrabt
Oct 5, 2015 05:23 PM
Boltons991qtr
Sep 20, 2015 06:57 PM
vogz
Sep 19, 2015 01:02 PM
