Surprises and now I need a better intake!
Old Jul 1, 2010 | 07:05 PM
bsprad's Avatar
bsprad is infamous around these parts
I recently purchased a 996tt that I knew had some mods, but the previuos owner didn't know much about them. So I finally had the car up on a lift today and it was like Christmas! I discovered that, in addition to the ECU flash I already knew about, I have a full Milltek header/cat/exhaust setup and Bilstein pss9 coil overs! I know that I should have had a PPI, but there were many reasons that it didn't happen. Anyway, at least the surprises were pleasant ones.
Here's where I could use some help. With such a good exhaust it seems silly that the car is drinking through a straw with the stock intake. I've looked around and read through many threads but I'm looking for some additional advice for a relatively easy DIY project to open up the intake. The fabspeed intake looks like it would help things quite a bit to start. I'm not ready to do a massive overhaul of the intake for many reasons, not the least of which is the cost.
Any suggestions?
Old Jul 1, 2010 | 07:14 PM
landjet's Avatar
Evoms' unit is now half the price it used to be and a proven piece. You'll still have to drop the motor a little to get this changed out.
Old Jul 1, 2010 | 07:37 PM
what do yo mean by intake? airbox?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 1, 2010 | 07:44 PM
bsprad's Avatar
Airbox and any other easy replacements that will allow the car to breath easier.
Old Jul 1, 2010 | 08:19 PM
Turbo Fanatic's Avatar
skip on the airbox...
Old Jul 1, 2010 | 08:31 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
+1 to Ari. With stock K16's there is no gain to be had in changing the airbox.
Spend your money on track time.
Old Jul 1, 2010 | 08:40 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
replace the filter with a K&N panel for now (but check that there's not already one in there first, red filter material color, think the stock one was yellowish)
Old Jul 1, 2010 | 09:13 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
beware of an oiled filter it can get have a neg affect on your maf
Old Jul 1, 2010 | 10:12 PM
landjet's Avatar
Oops, I thought you meant air intake down to the turbos when you said "sucking through a straw".
Old Jul 2, 2010 | 06:44 AM
bsprad's Avatar
It does have the K&N filter installed. It sounds like there isn't much of a reason to do anything else for now. The stock turbos get all of the air they need through the stock air box?
Old Jul 2, 2010 | 06:53 AM
John H.'s Avatar
John H. has a spectacular aura aboutJohn H. has a spectacular aura aboutJohn H. has a spectacular aura about
If you over-oil it...
Is there a better than stock filter available that you don't oil? I'd keep the stock airbox.
JH
Old Jul 2, 2010 | 11:45 AM
FAST FWD's Avatar
JH
Kevin at UMW, a/k/a Yoda of the Turbo, recommends stock air filter. I switched back to that after I installed Kevin's Stage 2A kit.
Feelgood MD
Mar 24, 2016 09:35 AM
Sales@RSW
Sep 16, 2015 06:03 AM
johnny.dangerous
Sep 15, 2015 11:19 AM
cm09578
Sep 9, 2015 02:16 PM
