Torque wrench calibration!!!!
Old Jul 4, 2010 | 11:27 AM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Did you tighten the bolts in a star pattern as you would a wheel lug? If not, that is probably why they came loose. 60ft/lbs is the correct torque for the bolts.
Old Jul 4, 2010 | 11:31 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Originally Posted by jpflip
Good morning Sunnyside. I also used sealed calibrated torque wrench for my work (transport Canada rules) and this is the one I used to retorque the drive shaft yesterday. The old one, I used normally at home never had any calibration and will never be used again. But mistake is always possible. I'm wondering about the grease I used to install those bolts combine with under torqued.... Anyway I will keep an eye on this more often.... Thanks for the reply!
Hi JP, hope you are well.
Just a quick question on a different topic, are you still 4 wheel drive. I ask because your rear shaft issue is an excellent way of showing just how poor the 4 x 4 system is on the 996tt. It takes just one wheel to loose traction ( ok in this case a shaft but same outcome) and no drive from the front wheels. If your still 4x4 it interesting to know the extent of drive loss to the front with loss to the rear.
Glad your ride is fixed,
Frank.
Old Jul 4, 2010 | 11:49 AM
jpflip's Avatar
Star pattern was used and I progressively increase the torque. Thanks for the reply because I am trying to get a GT-3 manual to found what torque they are using for this coupling....
Old Jul 4, 2010 | 11:53 AM
jpflip's Avatar
Frank.
Yes Frank I'm still 4 X 4 and without this shaft connected I was not able to move. Just about very slow walking speed.... Strange because in reverse I had a little bit more efficiency. It was a really strange feeling
Old Jul 4, 2010 | 11:58 AM
Cheers mate, thats what I thought. I would imagine that a single wheel high power spin ( no lsd) would have similar effects. ie little drive to the front. Makes me think about all the posts about removing the front drive.
Sorry about jacking the post.
Frank.
Old Jul 4, 2010 | 12:39 PM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
i didn't, i just torqued those by hand as hard as i could. Let say i was kind of in a hurry to get it working, if you know what i mean...
Old Jul 4, 2010 | 12:54 PM
jpflip's Avatar
We won't start another forum war with our french accent...
Old Jul 4, 2010 | 07:20 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
Another point to consider. I will order a complete set just in case...Thanks for the reply!
post reminds me, had this happen on my s2000. diff had been out on several occasions. it was scary, lifted the car up and saw that all the bolts had backed out, loose by hand. didn't do the work myself that time, so not sure if install error was the cause. but believe it's recommened by the factory (my tuner also recommeneded) to change bolts to new units which I promptly did. didn't have issues after that.
be interested to know if this is also the case for 996tt. A lot more power, I'm sure they'd just snap under similar circumstances.
frank - if i change to RWD, this will be your fault!
Old Jul 4, 2010 | 08:43 PM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
After reading all of this, I immediately went to the garage and made sure that my adjustable torque wrench was dialed back to zero! Glad that everything turned out OK, and thanks for spreading a little wake up call.
Old Jul 5, 2010 | 12:41 AM
dingo32
Sep 10, 2015 08:16 AM
porsche42
Sep 4, 2015 08:21 AM
zuman
Sep 3, 2015 08:27 AM
