What's in your Tippy? (Tip tronic)??
Old Oct 23, 2010 | 01:38 AM
  #61
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Originally Posted by adam699
So today, after months of searching, a failed order through VW NA and a lost package through Ireland Post......it finally showed up ob my doorstep!!! Yes the tiny bearing is here.
Please guys keep your fingers crossed. I'm attempting to put this beast together today again. Hopefully everything goes smooth.
Good news, I have my fingers and toes crossed for you.
I did my ATF change but am still getting slip changing form 3rd to 4th especially under full load so looks like my Tip is on the way out.
Frank
Old Oct 23, 2010 | 02:22 AM
  #62
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Good luck Adam!!
@ Frank, sorry to hear that! How many km do you have??
Old Oct 23, 2010 | 03:37 AM
  #63
Originally Posted by alex55
Good luck Adam!!
Hi Alex,
How are you, been a while since we have spoken. How is your car. Did you get the PSM/Abs fixed. I cant remember if you have said.
Well the box has done 52,000 miles. The slip & clunk is not excessive at the moment. I have adopted a manual approach to changing in that gear. That is I ease back off the power just a little when changing. Stops the slip & clunk.
To be honest , not that I want it to break , as soon as it does I will send it to MKB for the upgrade. That is the foundation for the next power mods to the car .
Frank
Old Oct 23, 2010 | 05:14 AM
  #64
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Well guys. I'm halfway done with the project. I just have to put the suspension back together and refill the fluid and go for a test drive, but it's 6AM here and I'm pretty beat after pulling an all-nighter.. thank god it's saturday...
Old Oct 23, 2010 | 08:17 AM
  #65
alex55's Avatar
Originally Posted by Sunnyside
Hi Alex,
Frank
Frank I don't have any issues with the car (thank GOD!) maybe it was somebody else.
From what I understand the packs between 3 and 4 are small...
Old Nov 27, 2010 | 12:13 AM
  #66
triplej's Avatar
triplej is infamous around these parts
Adam,
How did you get on with solving the whine? I have a very similar issue / noise in my manual (i'm assuming the AWD transfer is similar in both?). To recap.... around 40-50 mph and on over-run it really howles, above and below that speed range its fine.
Old Jan 19, 2011 | 08:33 PM
  #67
triplej's Avatar
thanks Adam,
I've had it checked by a few P gbox experts and they seem to think its the main pinion bearing. Almost as common as 2nd gear pop-out im told.
Old Jan 19, 2011 | 09:58 PM
  #68
adam699's Avatar
Originally Posted by triplej
thanks Adam,
Well, that's actually where I've arrived at at this point. After the transfer case surgery I still have the whine. The only bearing I haven't touched and I've changed 99% of them by now is the rear differential pinion bearing which is what I'll tear apart next doesn't look too challenging from looking at it. Funny thing thou, in my quest to fixing this I've came across many bearings that looked overheated, damaged and spun so in a way it's a good thing that I've had the opportunity to catch them before any major failure.
If you don't mind me asking, how much did they quote you for the job?
Old Jan 19, 2011 | 10:30 PM
  #69
triplej's Avatar
Yeah thats what really hurts of course. I've got 2nd gear issues as well and they are takling $6K to $8K depending on what else they find in there. If it has damaged the C&P as well...add another $3K.
Old Jan 20, 2011 | 05:15 PM
  #70
adam699's Avatar
That's a steep price tag. considering the market value our cars hold at this point. I'll try to do a writeup on the pinion bearings. Anyone have an idea as to what the preload should be on these in a tip?
Old Jan 20, 2011 | 06:28 PM
  #71
triplej's Avatar
Im in Australia and just about died when I saw what these cars are now worth in the US. They cost 4x as much here on the 2nd hand market and 1 USD = 1 AUD at present!
Old Jun 8, 2011 | 08:02 PM
  #72
adam699's Avatar
Guys wish me luck, I'm tearing it open again today as none of my crazy fixes solved the whine
This time I'm going straight for the rear differential pinion bearing which involves taking the whole front of the trans apart, again....grrr
I'll post up some pics once I get to that part.
Old Jun 8, 2011 | 08:19 PM
  #73
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
Hey adam, best of luck on your trans build. I had my self a leaking trans in my 997tt and gave up because I found renntech has their upgrade for the 996/7 tt tiptronics. Maybe someone in their trans department can give you a hand.
http://www.renntechmercedes.com/www/node/480
best of luck'
Old Jun 8, 2011 | 08:49 PM
  #74
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
renntech is a great shop
Old Jun 8, 2011 | 09:00 PM
  #75
adam699's Avatar
Thanks guys. If I can't nip the problem in the butt this time I'll give someone else a try. I like the learning curve thou I'm halfway done with the teardown and I can't stress enough how much I love my MAXJAX
