Need some advise on the cause of these fault codes
Hello everyone, i have been getting these fault codes since i installed 3" inch y-pipe, cayenne turbo throttle body and a bigger T-Plenum:
P1101 porsche fault code 594 - input variables charge measurement
P1249 porsche fault code 231 - boost pressure deviation below limit
p1130 porsche fault code 361 - oxygen sensing adaptation idle range bank 2 exceeds limit value
Any help will be appreciated, Thanks.
Please check all the hose connections at and after the TB. You most likely have a leak.
