Replacement rear rotors
Old Jul 14, 2010 | 03:45 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
Replacement rear rotors...any good after-market options
My rear rotors are right at the minimum thickness. Is there any plug and play after-market rear rotor that works better or should I just stick with stock?
My entire brake system is currently stock except for pagid blue pads.
Thanks!
Old Jul 14, 2010 | 07:02 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Thanks!
Do you track your car? If not, OEM should be fine. If so, you might want to consider Girodiscs. I've had much better life out of them.
Old Jul 14, 2010 | 08:42 PM
landjet's Avatar
I agree and Jon knows what he is talking about.
Old Jul 15, 2010 | 06:18 AM
landjet's Avatar
IMHO, same thing, more money.
Old Jul 15, 2010 | 07:11 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
is not better to upgrade to the 997tt rotors?
Old Jul 15, 2010 | 09:21 AM
landjet's Avatar
If you have the correct calipers to go with them, yes.
Old Jul 15, 2010 | 09:54 AM
alex55's Avatar
just to know, what is the price for swapping to 997tt brakes (front/rear)?
Old Jul 15, 2010 | 10:24 AM
landjet's Avatar
Check with Suncoast.
Old Jul 15, 2010 | 10:31 AM
alex55's Avatar
somebody here has changed them front and rear, at suncoast they are giving the price for the front gt3 kit
Old Jul 16, 2010 | 11:54 AM
NathanialHale's Avatar
NathanialHale is infamous around these parts
For the rears, you can re-use the 996TT caliper, but need to make (or buy) 12MM spacers and 997TT Caliper bolts... I'm doing it, and I know a several others who are.
NH
Old Jul 17, 2010 | 01:32 PM
I still don't think that is required to answer the question "IF" he just wants to move to the 997TT rear rotor. It's not much more expensive to replace, is larger and has a little more "lever" effect, and will clear the OEM rear wheels. I've not found the cross drilled rears to be an issue. It's when you are replacing the fronts due to heat checks, that's the real problem. I went with 350MM two piece units that are slotted and custom made by a non-sponsor for far less than the going price of any of the rotors mentioned.
NH
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
rnl
Aug 26, 2015 02:36 PM
awchristler
Bentley
Aug 24, 2015 03:53 PM
TrackOne
Aug 20, 2015 12:56 PM
