Tial a28 plus 5 bar fpr ??
Thanks.
I was never a fan of meth injection( yet one of cars has it)... but why mess with kits that often leak, you always have to watch it.... seen cars with them on and tunes not liking them.... I mean, how many guys have them, never have issues, do not have to worry when something goes wrong because the installer and or tuner is in their town and willing to look /fix the issue? etc etc... not bashing it but honestly... put on some GOOD ICs and call it a day.. same result and in the end probably cheaper... trust me...
2001 996TT 3.6L and stock ECU
I have the meth injection on my 997tt and we have at least 5-6 porsche turbos here with it. I broke the world tiptronic record, one broke the world VTG record. We haven't had one single problem. Actually, I'm a big fan of meth based on what I've seen. It's the first thing we've ever recommend to our friends who got a turbo car. Easy gains.. I have Proto 4,5 IC's and my friends have Switzer Monster IC's, Champion IC's etc... The difference at AIT with meth injection on vs off is way bigger than the stock IC's vs these IC's to say the least.. We have tested several cars and see the result ourselves.. And also increased octane level wouldn't hurt, especially on crappy 91 octane
then it looks like you have it figured out... that is the key.... especially the kit and the tune working together... BTW, 997s are a little different from 996s especially when it comes to turbos... and the heat they produce... but imagine a owner sends a car to another part of the country to get the kit installed... tuned etc... he gets the car back and 3 months later he has a leak and the car is not running right.... going into limp mode etc.... what does he do then? the local P car dealer will not fix it... I have seen this scenario locally twice... btw $1500 one way to ship the car to the installer... so it works great when it does... and or if you can do the work yourself... if not and something goes wrong then your in for big hidden costs not factored in initially. Im looking at it from a practical point of view of a owner with minimal wrenching experience who wants a turn key approach and is not trying to beat world records... otherwise you will be like us - 6" ICs, meth, Tilton triple carbon clutch, rwd, custom 17" wheels, 3 sets of turbos, etc...
Your math is flawed. 650 crank times 20% loss equals a 130hp loss, subtracted from 650 equals 520 whp. The loss is 20%, not 25. If you have 520 hp to start and you increase it by 25% then you would end up with 650hp.
Ive decided to take the advice ive got from everyone, so now car wont have 5bar, will have 60lb injectors. What boost will i be able to run safely and what power? Tia.
Im only about 2 weeks off it now
I would strongly suggest doing the inlet piping while there doing the new turbo's and clutch, quicker spooling. Ask me how I know
Good luck!
-David
-DIY 5-6hrs for inj. If you are not pretty handy, get the shop to do it.
-Blow throu maf uses Ford maf and relocates maf from right after Filter to be at Y-pipe. Around $3K+ tune.
-If your application is not 650+whp, for less hassle you could use Hitachi maf instead of stock maf. It could read lot more range than stock oe and no blow-up.
Are you saying it costs 3k to switch ONLY the maf?
HI,I was told by the tuner I used,who sold me the injectors also,,,That the 72lb Bosch were better all around then the Current type 60lb ones out now??...Good Luck...
depends which 60 lbs... but generally true... however they are also considerably more money....
Bad idea. You need Injectors. It will be laggy too unless you do the piping to turbos.
At least with injectors you have a base to build on. Just do injectors and turbos if you have budget constraints.... it's a great start
