Just Got My 996TT! Wheel/Tire Question
Old Jul 20, 2010 | 10:38 AM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Originally Posted by BOXER4
hmm....not to use a 295 huh I think I may have a problem then.. I have 235/35/19 fronts, and a 295/30/19's on 19x11 rear wheels is this bad?? if so LMK
The 295/30/19 and 305/30/19 is fine for the 997 giving it a close to 26" OD but the mistake which is common is some use the 295/30/19 in the rear since the stock tires were 295 in 18".... 19" changes it all... You should go to either a 305/25/19 or 315/25/19 to make it right. Not as big of a problem for the C2 but for the C4 C4s and Turbo it's not a good ideal....
-Eli
Old Jul 20, 2010 | 10:55 AM
ard's Avatar
ard
-Eli
BOXER-
the fronts are 25.5" and the rear is 26.0. Difference is 0.5" which EXCEEDS the [generally agreed upon] maximum of 0.3". Recognize that the stock wheel/tire 'mismatch' is 0.1" on the 996TT...so three tenths (0.3) is already more than stock specs. Your half inch is way too much, IMO
Unlike the 996TT, the 997TT has a 'designed mismatch' of 0.5", but the 996tt is designed for the same sizes front and rear.
Old Jul 21, 2010 | 09:03 PM
BOXER4's Avatar
BOXER4 is infamous around these parts
gosh I missed this reply....so it looks like they're coming off then. I didn't realize this when I bought the wheels.
thanks for the reply guys, I really appreciate it!!!
-Eli
Originally Posted by ard
BOXER-
Old Jul 21, 2010 | 09:41 PM
BOXER4's Avatar
wow....I was just looking for 305/25/19 rear tires, and wow, there's not too many choices ....I only have 11" wide wheels
Old Jul 22, 2010 | 12:50 AM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Wow you guys tossed him a super save, well done.
Old Jul 22, 2010 | 09:32 AM
Thumbs up
Pirelli is going to be your best bet to match the front and rear should you want to go with a matching set. 11" is totally fine on the 305 or 315, just got to make sure your set up is correct, PM or reply here if you have other questions regarding your set up.
-Eli
Some rep points would be nice...
-Eli
Old Jul 22, 2010 | 11:24 AM
BOXER4's Avatar
thanks Eli, rep points it is
-Eli
-Eli
Old Jul 22, 2010 | 02:21 PM
BOXER4's Avatar
so I guess I now have a set of as new toyo R888's for sale :P
Old Jul 22, 2010 | 07:13 PM
You should be able to find a buyer sooner or later, we sell them from time to time but not every day....
Good Luck,
Thanks,
-Eli
Jul 29, 2019 11:13 AM
horsepowerfarm
Aug 29, 2015 11:03 PM
ModBargains
Aug 20, 2015 12:28 PM
