3 gear pull durametric log
Old Aug 5, 2010 | 11:53 AM
Mr swed's Avatar
Mr swed is infamous around these parts
Hi Gents
I did some 3 gear pulls and logged actual values, the car is running 99 ron fuel,K16 turbos, 9ff exhaust with a euro tuner tune. I am not sure that the tune is correct.
input appreciated.
Regards Rob
File Type: pdf
Old Aug 5, 2010 | 02:50 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Originally Posted by Mr swed
Hi Gents
input appreciated.
Regards Rob
Looks pretty good - 1.0 bar max, injector duty cycles around 86% max. AFR's down around 11.7-8.
It would be nice to also log "Engine Load" at the same time. If you plot load vs rpm, you get a poor man's dyno curve. You don't know the actual value, but you can get relative numbers. You can compute hp as Load*RPM*pi/16,500, still also a relative number.
Old Aug 5, 2010 | 03:04 PM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Hi Fast Fwd,
I'm still playing with my new durametric. Could you please tell me how you worked out the AFR from the log shown. I can see the Lambda readings. What do you do with them to convert. Also how did you work out the inj duty cycle.
Cheers,
Frank
Old Aug 5, 2010 | 07:38 PM
FAST FWD's Avatar
Originally Posted by Sunnyside
Hi Fast Fwd,
Cheers,
Frank
Hi, Frank,
AFR = 14.7*Lambda
(14.7 is stoichiomeric ratio for air / gasoline)
Duty cycle = Injector time * RPM / 1200
(time ms)*(0.001 s/ms)*(RPM rot/min)*(1/60 min/s)*(1/2 intake/rev)*100%
Bar = (Boost - ambient pressure)/980
I wish I knew how to convert Durametric load (or torque) to ft-lbs... I asked Durametric and they said they don't know - they just report what the ECU tells them.
Jon
Old Aug 5, 2010 | 11:42 PM
Mr swed's Avatar
Thanks for the input, Jon.
I will try to do some runs this weekend.
Old Aug 6, 2010 | 01:50 AM
Cheers Jon
Frank
Old Aug 6, 2010 | 04:15 AM
Hi, Frank,
Jon
Most of the maps are set up in RPMs vs. engine load.... that goes for corrected afrs, target afrs, the 4 ignition maps... ironically some of the boost maps are rpms vs engine temp... thats kinda odd but oh well thats the Germans.. lol...
here is a sample... stock 996 target AFrs... RPM vs. engine load...
Uploaded with ImageShack.us
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 6, 2010 | 07:33 AM
Mr swed's Avatar
Marksi I cant see the sampel!
Old Aug 6, 2010 | 07:36 AM
Hi Markski,
I cant either, just a red cross.
Frank
Old Aug 6, 2010 | 07:50 AM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
If the datalog shows 2304 as boost, do you subtract 980? 2304 - 980 = 1324 or 1.324 bar?
Old Aug 6, 2010 | 08:26 AM
Mr swed's Avatar
No you take boost 2304-ambient pressure / 980
In my case average boost (1920 - 1008) / 980 = 0.93 bar
Old Aug 6, 2010 | 08:33 AM
FAST FWD's Avatar
The boost reported is in mm of Hg. To correct for the ambient conditions, subtract the reported boost pressure at idle. In Rob's dataset, that was 1008.5. To convert to bar, divide by 980 mm Hg, which is the definition of 1 bar.
Bar = (Boost pressure of sensor - Boost pressure at idle)/980
Jon
Old Aug 6, 2010 | 08:36 AM
FAST FWD's Avatar
I can't see those data either. I didn't get a baseline for my car before it was modded. I'd really like to see that dataset. I suppose that one could convert the engine load to advertised torque from Porsche to get a dimensional number.
Jon
Old Aug 6, 2010 | 10:13 AM
Sorry does this work?
And here is a ignition map....
9.66
click to view
Old Aug 6, 2010 | 10:34 AM
FAST FWD's Avatar
Well, I can sort of read it, but I'm not sure what it means.
If you could post a Durametric output of Engine Load vs. RPM in stock trim, I'd really appreciate it.
Thanks,
jon
