Fuel pump, fuel pump, fuel pump
Old Aug 10, 2010 | 05:51 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
I had just filled my car with 93 octane, after running a blend of 93/100 on track. When I started it, it immediately stalled. Started again, and it seemed ok. It stalled a couple more times at idle, and once when turning a corner. Then the problem went away. Car ran fine for several days.
I called Kevin (@UMW) to confirm that it was just the change in fuel grade. He said "Fuel pump, fuel pump, fuel pump!" I said, "But, what about the fuel..." and he said "Fuel pump!" According to Kevin, the problem shows up first at idle, where there isn't much fuel draw, so the loss is enough to make the car stall.
As usual, Kevin was right. See pic below. New pump installed. I'll replace the split hose and keep it for a backup.
Jon
Old Aug 10, 2010 | 05:55 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Too bad it happens,but lucky to find out soon
Old Aug 10, 2010 | 05:58 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
It seems that sooner or later we all will have to cope with that....
Old Aug 10, 2010 | 06:00 PM
FAST FWD's Avatar
Better this way than a total failure at Road America in two weeks!
Especially since it's a BMW school.
Jon
Old Aug 10, 2010 | 06:34 PM
jpflip's Avatar
Fast, keep your old pump, you can get a Saab line that fit perfectly and it is fuel proof.... Saw that on Rennlist in the GT3 996 forum....
The SAAB fuel pump repair kit is here: http://www.scantechproducts.com/carp...-50.5142.1.php
Thanks to Michael B. from Rennlist!
Old Aug 10, 2010 | 06:50 PM
FAST FWD's Avatar
Merci, Monsieur Flip!
Yes, I have a chunk of fuel-proof line inbound.
Jon
Old Aug 10, 2010 | 06:56 PM
jpflip's Avatar
Jon
Bienvenue Monsieur" Vite de l'avant" It is good to know someone somewhere got a used pump
Old Aug 11, 2010 | 08:36 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
There MUST be an easier solution to this than buying that whole kit...
One of the posters on that thread said he used a silicone hose similar to the other "clear" hoses on the pump...
Old Aug 12, 2010 | 05:19 AM
jpflip's Avatar
Agree Paullumn and of course this line has to be fuel resistant. But my concern is the bend. In the kit the line is already bend if you install a straight line I am afraid it will kink in the radius.... Do you have enough space to install a longer line with a wider 360 ' ??? But anyway if someone found a better replacement it will be really nice to know.
Old Aug 12, 2010 | 05:58 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Any decent idistrial hose n fitting supply should beable to get you a hose that wouldn't fail for probably less then 40$ even if they fabricated it out braided line, with custom braised together fittings
Old Aug 20, 2010 | 08:55 AM
Lysoleverywhere's Avatar
Lysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really nice
what went bad on your pump? I installed a new pump / venturi tubes last fall.
Old Aug 20, 2010 | 10:11 AM
Prche951's Avatar
The turbo fuel pump is ugly, it looks like an octopus. The other day driving in my area, I saw what looked like one of our pumps. I am sure it could not be, but I almost stopped to pick it up.
Anyway, how much did the replacement pump cost.
Old Aug 20, 2010 | 10:30 AM
600or so for the pump
jpflip's Avatar
Item #4 on the picture. There is a supersede number which is 996-620-108-02 according to Pelican and it is about $600.00. Saw it also at $537.00....
Old Aug 20, 2010 | 11:31 AM
FAST FWD's Avatar
My indie, who gets a lot of my business but is also a good friend, got mine for me at his cost + $0.25. (He gets tired of me complaining to him that he needs to make a living and should mark up my parts. This way he can claim that he did. )
The part that failed on mine was the short U-shaped fuel line that lives inside the tank. See the photo I posted. This seems to be the most common failure mode on this part. The upgraded version uses a different material (silicone I think) for that tube. In retrospect, it would have saved a lot of money to pop off the top, remove the sender and take a look. Could have gotten by with replacing that hose. But, after I fix it, I'll have a spare.
Jon
adnanm3
Nov 22, 2023 02:43 AM
pwdrhound
Sep 13, 2016 10:44 AM
XLR82XS
Oct 5, 2015 07:02 AM
