How much HP on 93 pump?
Old Aug 17, 2010 | 09:21 AM
Fastfrank's Avatar
Fastfrank is infamous around these parts
Tial Alpha 3071's, 70 lb injectors, RAI headers & exhaust,Evoms intake,EPL 1.3 bar tune
Purchasing a 996TT this week & it hasnt been dynoed-Curious if anybody has similar mods & how much power was made?
Thanks!
Old Aug 17, 2010 | 01:02 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
1.3 bar on 93 octane is risky. I would not run morethan 1.0 bar on 93. HP on that car should be close to 650HP.
Old Aug 17, 2010 | 01:09 PM
Prche951's Avatar
you can run that kind of bar with less timing. I am sure epl( if it is epl) is running proper timing with that pressure. But datalog records will tell all.
Old Aug 17, 2010 | 01:14 PM
Fastfrank's Avatar
It was @ 1.0 bar.....I will have to confirm where exactly it is now
Old Aug 17, 2010 | 01:30 PM
Divexxtreme's Avatar
Exactly. It all comes down to the specifics of the tune. I run 1.5 BAR on 93, and 1.6 on 100...and according to my non-stop datalogging, my AFRs are perfect and no timing is being pulled.
Next up; 104 octane at 1.7 and 1.8 BAR.
Old Aug 17, 2010 | 01:51 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Thanks!
I'm running the all same,except 72lb ~ 70lb??, 5 bar, 4.5 ic's plus water/meth injection, I haven't dyno'd it yet but damn , now I need tires
Old Aug 17, 2010 | 01:53 PM
2muchtime's Avatar
are you pulling any timing? few degrees? after 104 possible E85?
Old Aug 17, 2010 | 03:35 PM
I'm not 100% sure what you're asking, but I'll try and answer with what I've learned so far.
My tune isn't running much timing as is. But if you're asking if my ECU is pulling any more timing at high boost; no. It's the same at 1.5 BAR on 93 as it is at 1.2 BAR. Above 1.55 BAR, it does start to pull timing on 93, so I run 100 octane above that.
At around 1.65 BAR on 100, it starts to pull timing on 100, so I need better fuel to run beyond that. That's the maximum boost I've run so far, so I still have some more datalogging to do once I get some better fuel.
As much as I'd like to run E85, it just isn't common enough in my area yet to make it worthwhile for me.
Old Aug 17, 2010 | 04:09 PM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Switzer is running 1.5 bar with his P800 package on 93 octane putting arround 675whp.
Old Aug 17, 2010 | 04:15 PM
ttboost's Avatar
If this is on EPL's stingy dyno. I betting 460awhp...
Old Aug 17, 2010 | 04:28 PM
The numbers can be up or down depending so many factors... lest just hope its somewhere in the middle... where they should be... a proper install is one of them...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 17, 2010 | 05:31 PM
racegate's Avatar
racegate is infamous around these parts
What do you use to log the timing?
Old Aug 17, 2010 | 05:35 PM
Softronic cable, Durametric software and a laptop.
Old Aug 17, 2010 | 11:10 PM
cjv's Avatar
cjv
Moderator
E85 can support up to 2 bar.
adnanm3
Oct 25, 2016 08:38 AM
White991TT
Mar 8, 2016 06:01 AM
Glasgo
Nov 30, 2015 02:37 PM
panas001
Sep 27, 2015 02:51 PM
