Shift lever movement under acceleration?
Old Aug 17, 2010 | 10:24 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
How much does your shift lever move when you "get on it" or begin to accelerate?
My shifter surges forward about 1/4 inch when I go from part throttle to WOT, in gears 1,2,3.
Tom
Old Aug 17, 2010 | 12:26 PM
VAGscum's Avatar
Check your motor and tranny mounts. If they are shot you can get this.
Old Aug 17, 2010 | 01:41 PM
tvurt's Avatar
I was thinking trans mount, not motor. I will check both.
Thanks,
Tom
Old Aug 17, 2010 | 02:11 PM
VAGscum's Avatar
Thanks,
Tom
Check both. It may only be the tranny mount but a bad motor mount puts more of if not most the dampening on the tranny mounts and will cause excessive movement and visa versa. The motor/tranny combo relies on on both functioning mounts otherwise driveline slope will occur.
ModBargains
Oct 13, 2015 03:43 PM
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
