Agency Power Race Plenum Throttle Body
Old Aug 17, 2010 | 07:14 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Originally Posted by steve harris
os got that thanks was thinking about fitment, also with my small turbos am i subject to over spin??
negative ghost rider, you can put any of these mods on and be safe steve now how much power they will give with k16's versus big turbos now thats a different story. Bigger turbos will benefit much more from these kind of mods then small ones..
Old Aug 17, 2010 | 07:25 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
thats why i have not introduce a y pipe to my 16 hybrids. am thinking they can,t handle anymore air, am i dreaming??
Old Aug 17, 2010 | 07:32 PM
ttboost's Avatar
No such thing as "too much air". Less restriction is less restriction...period. It's just a mod that isn't as noticeable as it is with bigger turbos...
Old Aug 17, 2010 | 07:35 PM
there is a .5" diameter lip in the y pipe that you would cure which has to be worth something. look at Speed techs photos john has a great picture of it.
its always good to replace the weakest link in the chain and improve flow the question becomes then how much difference would you see at your CFM level. i would expect a difference but is it a 1600$ difference to you?
also remember that Boost is a measure of restriction so in fact after you clear up the restrictive intake pieces you might see a drop in your boost # a little bit but that doesn't mean your cfm(cubic feet per min of air) drops. this assuming you have no known leaks.
Old Aug 17, 2010 | 07:41 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
the plenum/TB mod made big improvements for me. I have a customer who gained another 5% of HP by adding our Y pipe along with the Plenum and TB he already had.
Old Aug 17, 2010 | 09:20 PM
Brad Bedell's Avatar
Brad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to behold
I know what I"m doing when mine is apart...
Old Aug 17, 2010 | 09:49 PM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
Im doing this mod with a rear intake pipe upgrade. I want to get some good IC's and then do the Y-pipe I think that should free up all the restrictions.
Old Aug 18, 2010 | 11:51 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Sounds like it only fits well if you change the Y pipe too, but if you had to choose between the Y pipe and the Agency Race Plenum which would you go for and what are the relative labor costs for installing each independently ?
Old Aug 18, 2010 | 12:40 PM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
I am happy with how mine fits with the factory y-pipe. Secure and bolted.
This is one of those . . if you have done everything else mods . . ..
The y-pipe would be much easier to do, taking out the y-pipe is simple compared to the TB.
Tom
Old Aug 19, 2010 | 02:11 PM
RCH's Avatar
RCH
Yes I am still thinking Y pipe too, do I have to also drop the motor for that ??
Old Aug 19, 2010 | 02:17 PM
no maybe remove bumper if you cant get the intercooler hose clamps on.
now if your talking about a Blow through MAF with fender well intakes and removing the stock inlet tubes you might have to drop it to get them out. some people have had luck cutting them without removing the motor though.
drinaldis
Sep 28, 2015 01:37 PM
turbotuner20v
Sep 11, 2015 12:02 PM
magoochi
Aug 23, 2015 05:54 PM
VGLNTE1
Aug 20, 2015 08:14 PM
