Agency Power Race Plenum Throttle Body
Old Aug 17, 2010 | 12:55 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
http://www.vividracing.com/catalog/a...5-p-86099.html
What do you Guys think of the Agency Power Race Plenum ? Look's like fitting time is relatively short ? Performance differences ?
Old Aug 17, 2010 | 01:08 PM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
I like mine. It moved the spool of my k24/18g about 150 rpms lower.
Fitting is a bit time consuming, but basically easy. Drop your engine off the mounts, take out the old, put in the new. Do a boost leak test after EACH part is installed to make sure you did not bump/disconnect any lines.
It will sit about 3/8 inch further back, so you can only use the middle bolt to secure the y-pipe, but I feel the y-pipe is plenty secure with that.
Here is how mine sits, installed.
Old Aug 17, 2010 | 01:11 PM
RCH's Avatar
RCH
tx. but it didn't mention dropping the motor in the online install guide right ?
http://www.agency-power.com/blog/tec...-instructions/
Old Aug 17, 2010 | 01:33 PM
tvurt's Avatar
Dunno, I just pulled it out and replaced. It is a straight forward procedure, but you are messing with about 15 different vacuum / pressure connections and it is easy to get a leak.
Old Aug 17, 2010 | 01:40 PM
RCH's Avatar
RCH
tx. vm just did a search and it seems not everybody found it that easy
https://www.6speedonline.com/forums/...well-kind.html
Old Aug 17, 2010 | 01:45 PM
tvurt's Avatar
Took me about 6 hours over a few nights. I could had it done much faster, but I did not boost leak test after several steps, and ended up with 3 leaks, and had to take it all apart again .. . twice.
Tom
Old Aug 17, 2010 | 02:15 PM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
so overall what difference does it produce.
Old Aug 17, 2010 | 02:32 PM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
I am curious to know what the advantage of this unit is compared to the RSS plenum which is only "about" $200 more. Looks very similar to the stock design where as the RSS plenum has a "Y" design..... The Agency power unit come with a TB so that looks like a nice advantage over the RSS unit.
We need to see these two units go head to head!
Old Aug 17, 2010 | 04:17 PM
Brad Bedell's Avatar
Brad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to behold
RSS plenum and this aren't the same. The RSS is just a plenum, this is an upgraded throttle body and plenum. You'd have to compare RSS + throttle body to get the delta. So, say 400 for TB, 900 for Plenum, you're more around $600 price differential.
Old Aug 17, 2010 | 05:28 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
I did the TB/Plenum and noticed faster spool, and some power, then added Y pipe and IC,s which was more noticable, everything fits fine now.
Old Aug 17, 2010 | 05:34 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
Which company made each of your products....TB/Plenum, Y-pipe and ICs? Any pics? Which turbos do you have?
Old Aug 17, 2010 | 05:40 PM
drhenrock's Avatar
Everything is AP from Vivid, FVD flash, stock turbos, for now...Pics on Vivid sight.
Old Aug 17, 2010 | 05:52 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
will this fit with a evo air box??? and hows the match with kevins k16s??
Old Aug 17, 2010 | 06:41 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Steve these products discussed here are not affected by air box or turbos these are behind the throttle body.
The object of these products is to increase airflow bigger throttle body flows more air then the smaller one at the same throttle posistion, also you could see a spool increase if the throttle body was a large restriction in your intake tract.
If you upgrade the y pipe infront of the throttle body you remove a nice air restriction also.
Old Aug 17, 2010 | 06:58 PM
os got that thanks was thinking about fitment, also with my small turbos am i subject to over spin??
