My key is getting hard to get in and out of the ignition,
Old Sep 1, 2010 | 06:02 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
it is hard to turn as well, any ideas?
Old Sep 1, 2010 | 06:28 PM
raineycd's Avatar
From what I have read, it is a pretty common problem with the ignition switch going bad. Do some searches and you will probably come up with a fix.
Old Sep 1, 2010 | 06:39 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
time for new switch mines been replaced atleast once and was acting up last time i drove her
Old Sep 1, 2010 | 07:30 PM
landjet's Avatar
Agreed.
Old Sep 1, 2010 | 07:36 PM
GXL's Avatar
GXL
GXL is a glorious beacon of lightGXL is a glorious beacon of lightGXL is a glorious beacon of lightGXL is a glorious beacon of lightGXL is a glorious beacon of light
I had the same issue. First a sticky key, then an occasional message that the key was still in the ignition when I had already removed it. I was told to replace the faulty ignition switch as this behavior was a signal that it was soon to completely fail. About $200 for the part, I think about 1.5 hrs labor charges.
Old Sep 1, 2010 | 07:57 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
Suncoast has the Audi part for around $20
Old Sep 1, 2010 | 08:29 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
NAPA has the part for $9.17. I did this on my car last week. Takes about 1-1.5 hours, depending on how well you work inverted with a clutch pedal in your ear. There is a DIY with photos on renntech.
Jon
Old Sep 1, 2010 | 08:46 PM
sav911's Avatar
sav911 is infamous around these parts
Part is 4A0-905-849-B-M5352
It's a VW/Audi part. It is a pain in the ***, simply because you have to access it from behind the dash.
Remove the A/C duct directly below the steering column.
Remove the plug from the end of the switch unit.
With a stubby jeweler's screwdriver, loosen the two screws. Mine had red loctite on them, and were a ***** to get loose, since it was nearly impossible to get my arms up in there in the first place.
The switch then pops right off - then reverse the process. While lying on your back over the door sill with your head and arms wedged under the dash.
Old Sep 2, 2010 | 12:25 AM
MkC2S's Avatar
buy extra...b/c they will f..up again later down the road...I know
http://industryfigure.com/berkeley/P...tionswitch.htm
(it said boxster but should be the same for 996)
Old Sep 2, 2010 | 05:24 AM
FAST FWD's Avatar
It is a bit easier if you remove the a/c vent on the left side of the dash. To do this, first remove the headlight switch by pulling it toward you, and pressing up with a thin screwdriver underneath the part that pulls out to release the spring clip. This reveals a hole on the right where there is a torx screw that needs a long bit to reach. You could also use an allen key if your torx isn't long enough. Then remove the two torx screws on the side of the dash that are revealed when the door opens. Gently wiggle out the left side of the dash that contains the a/c vent. Finally, remove the phillips head screw that hold in the air duct (you can now see it through the hole) and pull down the up-part of the a/c duct to remove it. You can now reach through the hole to get to the screws that remove the ignition switch. I could only get the top one this way, and I still had to go below to get the other one. But that made for not too much time doing the work from below.
Here's a link to the DIY:
http://www.renntech.org/forums/index...with-pictures/
Jon
Old Sep 2, 2010 | 05:39 AM
drhenrock's Avatar
I love this forum, Thank you for the help!
Old Feb 16, 2013 | 11:27 AM
996landjet's Avatar
996landjet has a spectacular aura about996landjet has a spectacular aura about
Very helpful post and links, and it definately saved me some $$. I would also suggest a good flashlight (one that is small and has a clip so you can get light wher you need it, hands free) I also had difficulties getting the air duct reinstalled, and found myself questioning whether or not I really needed it. but attaching the clutch side first (as suggested) made it easier and I finally got it back on. (great advice!) Also, I noticed that the clutch-side duct that I was trying to reconnect to had dropped slightly during removal. After I pushed upward on it, to give the connection more clearence, it went right on.
FUTURESTAR
Sep 23, 2015 05:42 PM
Korntera
Sep 15, 2015 08:20 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
albert@velosdesignwerks
Sep 3, 2015 11:11 PM
Suds26
Sep 2, 2015 01:33 PM
