Need new clutch ... suggestions?
Old Oct 4, 2003 | 12:05 PM
DarioTexas's Avatar
Senior Member
DarioTexas is just really niceDarioTexas is just really niceDarioTexas is just really niceDarioTexas is just really nice
I'm assuming a new clutch isn't under warranty soo ... what do you guys suggest is the best aftermarket performance clutch to get? CJV or Shank?
Dario
Old Oct 4, 2003 | 12:16 PM
msindi's Avatar
Id say go for the Scahs Power clutch...
Old Oct 4, 2003 | 12:17 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
evoms.com ?
996TT Transmission Upgrades
Sachs GT-1 Clutch Kit Upgrade LEVEL 1 (STREET) : This level 1 upgrade will support up to our level 4 power system. This system consists of a new Sachs GT-1 pressure plate with increased 3500 lb. clamping force, GT-2 sport lined disk and new throw out bearing. 100% daily drive able with little increase in clutch pedal effort. Smooth engagement for everyday use.
Model Year Description Part Number Price
996TT/GT2 2001- Sachs Street Clutch Kit Level 1 CLU996TTL1 $1495
Sachs GT-1 Clutch Kit Upgrade LEVEL 2 (STREET) : This level 2 upgrade contains all of the level 1 system and incorporates solid billet flywheel. The OEM 28 LB. dual mass flywheel is replaced with this solid 12 lb. flywheel. The weight reduction allows the motor to rev quicker for better acceleration. This stronger clutch kit will support up to our level 5 power system. Offers 100% daily drive ability with little increase in clutch pedal effort. Smooth engagement for everyday use.
996TT/GT2 2001- Sachs Street Clutch Kit Level 2 CLU996TTL2 $2195
Old Oct 4, 2003 | 12:20 PM
cjv's Avatar
cjv
Moderator
Dario,
The best one available is the Tilton. Available from S Car Go. Three small carbon ceramic discs about 6" in diameter. Expensive, about 4K parts only. The next best in my opinion is one The Racers Group sells. It is about $1,400. dollars. It worked well at over 700 hp for me. Contact Ryan at The Racers group.
Both these set ups shed alot of weight. The S Car Go clutch will take 10,000 rpm's and is extremely light. The Racers Group set up still sheds about 60 pounds from the stock unit and is extremely durable.
Old Oct 4, 2003 | 01:03 PM
bbeasley's Avatar
bbeasley is infamous around these parts
Dario,
As an autocrosser I'm always concerned about my launches and the effect on the clutch. How many miles is on your car and what kind of use/racing has it seen?
Old Oct 4, 2003 | 07:53 PM
PorschePhd's Avatar
I will throw my hat in here as well. We have a custom disc made for us with a modified GTII pressure plate and a L/W FW. Keeps the jitters away under load and well hold some pretty stupid power. This is not one of the other kits you see, rather something we used from the G50s and built for the 996TT. Lots of similar things here.
Old Oct 4, 2003 | 08:15 PM
sharkster's Avatar
How about a custom upgrade for the monkeytronic tranny then?
Old Oct 4, 2003 | 08:17 PM
PorschePhd's Avatar
Come to OZ and I bet the munchcins will make something
Old Oct 4, 2003 | 08:37 PM
sharkster's Avatar
ROFL!!! Good job I had already been to the loo ths afternoon... That sounds good. Cold air as well
PS You know my homemade powerglide rox.
Old Oct 4, 2003 | 09:21 PM
DarioTexas's Avatar
Senior Member
bbeasley - my car is an 02 with 37k miles, I know how to drive and rev match properly however, I've loaned my car out to people who probably don't, so don't know if it's just natural wear and tear or other...
PorschPHd - how much is your clutch setup and are you familiar with the SCargo setup to compare?
CJV - thanx
based on what Ryan at S-car-go and what others recommend plus availability I will have my service rep order Monday ... anyone know how much labor should be on the install ...
Thanx
Old Oct 4, 2003 | 09:56 PM
cjv's Avatar
cjv
Moderator
Dario,
My first clutch was installed by The Racers Group about two years ago. Labor and material was $2,000. I believe the Tipton three disc carbon ceramic is the same clutch used on the C-GT. They need your flywheel for machine work. The cost parts and labor is about $5,000.
Old Oct 5, 2003 | 08:04 AM
ben, lj's Avatar
Senior Member
"I believe the Tipton three disc carbon ceramic is the same clutch used on the C-GT."
Is this what you have now? Is it stiff like many of the magazines are moaning about the CGT's?
jaehoppa
Oct 22, 2015 09:17 PM
ship it
Sep 7, 2015 10:49 AM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
