Help - strange sound while driving
Old Sep 2, 2010 | 03:47 PM
mcisprinter's Avatar
mcisprinter is just really nicemcisprinter is just really nicemcisprinter is just really nicemcisprinter is just really nicemcisprinter is just really nice
Help - strange sound while driving ** update **
When I am driving, I hear a slight "woop woop woop" sound that speeds up as I accelerate.
The tires were changed and the wheels are properly balanced. The steering doesn't shake, everything is fine from that standpoint.
It occurs while rolling - clutch in or clutch out. Any ideas? Brakes are fine, no weird scoring on the rotors.
Could it be the differential? No weird noises while turning ... It really sounds like tires but they were switched and the noise hasn't dissipated
Thanks in advance
Old Sep 2, 2010 | 04:12 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
Wheel bearings. BTDT.
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Wheel bearings?
Old Sep 2, 2010 | 04:54 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
see if the woop goes away on a turn if so it's your bearings
Old Sep 2, 2010 | 05:13 PM
Thanks for the hint! Will investigate
Old Sep 2, 2010 | 05:30 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Wheel bearing
Old Sep 2, 2010 | 06:11 PM
PAULUNM's Avatar
In my experience the noise was constant even in turns.
Did a road test
When turning with the clutch in, sound was still there but when I turned left I would hear a grinding (very slight).. Turning right did not produce grinding
I called Porsche to ask about the warranty and they said it would be covered (I am on the new CPO after August 2008) if "no outside factors" could have caused the issue.
I have a PSS10 suspension with a standard (more road than track) alignment.. we'll see what they say.
Old Sep 2, 2010 | 06:43 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
could be a CV going bad.
Old Sep 7, 2010 | 06:30 PM
I called Porsche last week to ask them if wheel bearings are covered under warranty.. they said yes.
So, I brought it to the dealership today.. They confirmed it was the front right wheel bearing. Oh yes, not covered as it is "wear and tear".. about 600$.. 200 in parts and 3 hours at 125/hour.
I mentioned that last week Porsche said it was covered under warrant but the dealer said Porsche refused it.. My problem is obviously not with the dealer so I politely told him to go ahead and that I would sort it out with Porsche Canada.
Made the call and they assigned it to a "resolution specialist". I told them that if they have a document with my warranty that says wheel bearings are not covered as it is wear and tear I would pay the amount no problem... Let's see if I missed something in my warranty or if someone was confused at the head office.
Either way I am happy that it's most likely one of the least expensive parts that can break on the car!!!
Small advice for the future, if you ever call 1-800-Porsche and ask them for warranty info, have the rep log the answer and open a case.
Old Sep 7, 2010 | 08:25 PM
PAULUNM's Avatar
When I had a bad wheel bearing, I had my warranty pay for it- but I paid for the other side.
Best to do in pairs (if not all 4, but $$)
Marcos AMV8
Dec 18, 2015 06:03 AM
turbotuner20v
Sep 11, 2015 12:02 PM
richard2966
Bentley
Aug 22, 2015 03:33 PM
