Handling Question
Old Sep 18, 2010 | 08:29 AM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
Handling Question
when getting off the highway at a radius'd ramp or when making a turn and applying throttle I get the feeling like the inside front wheel is lifting and of course it under-steers. I dont need to be heavy on the throttle for this to happen. Yes, I know it a rear engined car, but as a relatively new owner, it seems to handle worse that my awd mitsu eclipse in these situations.
Any recommendations on what to work on to minimize this characteristic. The car is lowered and rides on 19" Champions.
Thanks in advance for your suggestions
Old Sep 18, 2010 | 12:23 PM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
19" certainly arent the best for optimal handling for the TT...
but, what kind of tire sizes and pressures are you running?
is your suspension stock or are you on coilover? if so what kind of settings?
Old Sep 18, 2010 | 03:11 PM
03 996tt's Avatar
Pirelli P-zero rosso 235/35 front and 295/30 rear with 36psi front and 42-43 rear. Just springs from what the previous owner told me.
While I know there is some debate as to the rear tire size, the tires were purchased from Champion. When I inquired as to the fact that the ratios may be off, The service writer looked in a book and confirmed that in fact they are fine.
Old Sep 18, 2010 | 03:23 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
Was the car re-aligned after the springs were installed? Also, most people with 19s run 315/25/19 rear not 295/30
Old Sep 18, 2010 | 10:34 PM
03 996tt's Avatar
the springs were installed several years ago and was aligned then and 1 time since. The car tracks straight, although it has not been aligned since I purchased it. I wish it had the 315's in lieu of the 295's, but since they were installed 5 mos ago (week before I purchased her and only 800 miles) and I recently became semi retired (unemployed) I cant see replacing them at this time.
Are there any known bushing or sway bar issues I should look for?
nlakind
Nov 6, 2015 10:15 AM
Sep 10, 2015 03:20 PM
away
Sep 4, 2015 12:30 PM
gulf gt
Aug 27, 2015 10:27 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
