help with power loss
I would appreciate any feedback from members.
I have a tuned '04 TT that had 700 rwhp. I recently installed a europipe stage II loud. The sound is phenomenal, however the car was re dynoed only to find a 50 hp drop in hp! Also, the "check engine" light came on. Any ideas? Sensor? Retune? Thank you.
which exact Europipe is it? what cell count is it? what cel count was the previous exhaust? did the same tuner program the car before and after the install? ruin the codes check what exactly came up....
You have to get a little more specific in order to help you... I don't think anyone here can read your mind...
How does the car feel? slower?
markski
2001 996TT 3.6L and stock ECU
Thanks Marksky.
I will get that information to facilitate an understanding of the situation. I have not driven the car. Its purely dyno numbers (same dyno). Same tuner, who changed the turbos and ECU etc., installed the europipe. I will ask for particulars. Previous exhaust was stock. Thanks again.
Thanks Marksky.
You had a tuned 04 TT with a STOCK exhaust with 700 WHEEL HP? ANy dyno sheets?
By "Tuner" are you referring to the person installing parts, or the actual person doing the ECU coding?
Thanks Marksky.
something is not adding up... look into it...
markski
I'm with Mark and A....something is amiss...don't see how you got to 700 with stock (restrictive) exhaust. Perhaps your other dyno was incorrect? EP does allow for more power as it is less restrictive (if it is a stage II then it is 100 cell)...regardless of previous poster. Your tune may need to be adjusted for the freer flowing exhaust. Never had a code with my EP.
On second thought just send me the exhaust...lol
COBB Tuning
Mar 29, 2016 09:26 PM
COBB Tuning
Sep 9, 2015 09:13 PM
Ferrari
Aug 24, 2015 04:35 PM
