2003 996tt
Old Sep 27, 2010 | 12:25 PM
jim hopkins's Avatar
jim hopkins is infamous around these parts
2003 996tt clutch help
Can anyone help? I have a 2003 996tt with 30,000 miles and at the last track day at high spped the Clutch started slipping. During the next sessions there was no slipping. after about a month I started to pass a car on the street and is slipped again then the rest of the day it was fine. Has anyone had to replace a clutch so early ? and what did it cost ?
Jim
Old Sep 27, 2010 | 01:25 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Jim
clutch if you want oem is about 1800$ for the clutch and 10-15hrs depending on shop to install.
there are much better options out there though for a clutch and you may want to find a lightweight flywheel (LWFW) since you track.
Old Sep 27, 2010 | 01:33 PM
bsprad's Avatar
bsprad is infamous around these parts
Are you certain that the clutch is slipping? What are your symptoms? My car was misfiring at one point and that felt like the clutch was slipping, but the rpm's didn't rise.
What type of mods do you have? Higher power than stock can make the clutch wear very quickly.
Old Sep 27, 2010 | 01:48 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
do you have any mods with your TT and how many mileage with your currently clutch? Replacement clutch is 16 hours labors on the book plus the clutch. You will save some money if not done it by dealer!
Old Sep 27, 2010 | 01:54 PM
heavychevy's Avatar
Could be this, make sure you check.
However, since you track, it could also be your transmission mount gone bad. Mine went bad and caused my clutch to slip so I bought a new clutch and then realized I didn't need to. Check to make sure your transmission mount isn't toast. They are very weak rubber and do not hold up to tracking very well.
Also, we would need to know your modifications as well. My clutch went at right about 30k as well with K24's and tune. An aggressive tune on K16's could do it too though.
Old Sep 27, 2010 | 02:46 PM
Thanks for your great help I wll keep you posted.
Jim
Terminator
Oct 7, 2015 08:12 AM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
gjpearce
Sep 30, 2015 04:26 AM
Fullthrottleguy
Sep 28, 2015 03:19 PM
