Anyone dyno one of these before and after ?
Old Sep 28, 2010 | 11:46 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Dual snorkel intake
http://www.vividracing.com/catalog/a...5-p-82003.html
or log MAF values before and after to see if there is an increase in airflow ? Or is it more of a cosmetic / sound mod ?
Thanks.
Old Sep 29, 2010 | 08:54 AM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
If I recall correctly, AMS saw around 10hp at the 600ish level, as well as about 1psi of pressure drop reduction pre-turbo.
Old Sep 29, 2010 | 11:38 AM
GMendoza's Avatar
GMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of light
What about reduced lag? If better spool times have been confirmed, that alone would be enough to upgrade in my opinion.
Old Sep 30, 2010 | 08:41 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
It has to help, cold air from dual snorkle, if you have a GT2 wing its even better, dyno cant reproduce the air flow over the wing at 60 + mph
Old Sep 30, 2010 | 09:08 AM
JSBear's Avatar
What about MAF airflow logs, g/s ? Seems like it would
be simple to log airflow characterstics with the Durametric, I know on my old B5 Audi S4 I could log MAF airflow readings in grams per second with VAGCOM cable and software. I would assume this would at least tell us the MAF is seeing more airflow from the dual snorkel design.
A bit surprised this has not been done, I will look to see if the Durametric can log MAF airflow.
Old Sep 30, 2010 | 09:45 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Yes, Durametric can log mass air flow.
Emre@Esmotor
Oct 19, 2015 12:06 PM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
