EVOMS TCU reflash - fixes torque converter lockup TSB?
Old Oct 3, 2010 | 08:35 AM
sav911's Avatar
sav911 is infamous around these parts
My 2002 tip has been diagnosed with the issue highlighted in TSB:3701 - basically bad TCU adaptation in stop-and-go driving causes the torque converter to lock up inappropriately, causing hesitation and grinding.
Anyone else have this problem, and attempt to fix with EVOMS' TCU upgrade? My understanding from the dealer (Porsche of Nashua, NH) is that it's basically a software problem, not hardware, but they can't reflash, only replace the TCU with an updated version. Replacement cost is ~$2000 ... while the EVMOS reflash is only $1000, and has the added benefit of improved programming.
Thoughts?
Old Oct 3, 2010 | 09:41 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
You'll end up spending 1k for the upgrade to find out it doesn't work then pay 2k for another TCU. And you'll never see any benefit of the TCU flash if you don't have a custom ECU tune to raise your rev limit.
Old Oct 3, 2010 | 10:21 AM
Dr_jitsu's Avatar
Todd knows what he is talking about.
Of course eventually you will realize that for big power you want a manual.
Old Oct 3, 2010 | 10:24 AM
sav911's Avatar
Thanks for the feedback. Looks like I should just replace the TCU. No plans to upgrade power any time soon.
Oh - to be clear, I'm not so interested in raising the redline with the TCU (which I know requires an ECU flash also) as much as keeping the transmission from upshifting so aggressively. This transmission cries out for a "sport" mode. The loaner A4 I drove for a week felt "sportier" in everyday driving.
Old Oct 3, 2010 | 11:34 AM
Upshifting aggressively? Not a bad problem to have. There's nothing "sporty" about the tip.
Old Oct 3, 2010 | 11:39 AM
willieboy's Avatar
willieboy is a jewel in the roughwillieboy is a jewel in the roughwillieboy is a jewel in the rough
+1
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
jaehoppa
Oct 22, 2015 09:17 PM
albert@velosdesignwerks
Sep 3, 2015 11:11 PM
zuman
Sep 3, 2015 08:27 AM
AdamNoone
Sep 3, 2015 04:12 AM
