Clutch issue, need advice
I've been scratching my head for the best way to handle this; any advice appreciated. 2005 TTS 13.9k miles with CPO warranty that I've owned for a couple of months. Overall goals for the car are probably no more than flash, intake, exhaust and other minor stuff. If it gets boring down the line maybe 24/18g. It is a daily driver.
Fantastic car, but I wanted a little bit more so I went with an EPL flash which works great and gives me consistent 1-1.1 bar. Pre-flash I had no clutch issues. About a month after flashing I started noticing some slipping during WOT, first in 5th, then 4th, and finally 3rd gears. Usually only at full boost from 5500-7000 rpms. The tach kept going but no power was going to the wheels. I initially thought I just sucked at shifting, since this generally happened only at max acceleration going through the gears. However, I have been able to recreate the slip while simply cruising in a gear and then engaging full throttle without a shift.
1. I can flash to stock and have the dealer take a look, but most likely this is wear and tear and I think I'll have to pay for the clutch anyways.
2. Private shop for my first independent inspection as a bonus in addition to inspecting the clutch. Have this shop replace with stock if needed versus upgrading the clutch. Any incidental findings I will then take to the dealer for CPO work.
3. Flash to stock and if I don't have any more clutch problems due to less torque, simply happily drive it for another year until I really need to change/upgrade it. I really don't want to do too much to it until CPO runs out.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
agreed, no point in putting a stock one in there since labor is probably as expensive as the clutch itself, why pay twice for labor?
Or you just get a couple of friends, find a lift and do it yourself if you are a little mechanically inclined.
if when you get the clutch apart realise a LWFW(light weight flywheel) is probably about the same price as the stock dual mass unit, so if you want some faster revs thats an option but do your reading they are noisey on these cars (i know i own one)
wow people do actually read my posts wewt!
O S the noise is an ez fix, its called straight pipes!
I am actually in a similar situation as you, altough with stock power. My clutch is slipping in 1st gear when launching ~3k RPM. There is pretty much no way around the $$...unless you stay stock..which you know won't happen
. I am just going to bite the bullet and spend the $5-6k for clutch upgrade, flash, and exhaust all at once. Now if I can only convince the wife...
. I am just going to bite the bullet and spend the $5-6k for clutch upgrade, flash, and exhaust all at once. Now if I can only convince the wife...He did quote me for replacing the clutch at $5,000. $1700 parts and $3300 labor. Is that reasonable? If you can get the flash and exhaust for the same price how are you doing that?
In terms of exhausts, I'd like a bit more aggressive sound but not too loud. I want to hear it when I WOT, but I don't want to hear it when cruising. Suggestions?
Since there is a long wait to get the car into the indy shop (end of october) I'm going to have the dealer take a look first. I also told him about 2nd-gear popout and he said depending on what is causing it, it will be CPO covered.
i recomend a x flow type exhaust. it really depends on where you want to go with the car how far. id say switzer, markski, speedtech, protomotive has a nice new exhaust.
be mindful on who does your flash alot of cars having trouble lately cause of edgy tuning.
tunes range from 1k-2k depending on the tuner.
exhausts 1800-10k for a akrapovic full system
dealership prices those sound about right but is that a stock clutch?
I already have an EPL tune and am very happy with it. Consistent 1-1.2 bar (if cold) bar with the rest of the car stock. In fact, prior to the tune I had no clutch problems. EPL gave me so much torque that it started slipping.
Listen to everyone as most have been down your road. I think everyone would agree the easiest way to waste money would be to have anyone put another stock clutch in the car. Remember, you could put a brand spanking new stock clutch in and it will not hold your basic tune. You'll be that $3300 lighter and in the very same position as you are right now with a slipping clutch. But at least you'd have a new slipping clutch!
There are several aftermarket clutch kits out there. Search a little and you should find plenty to help you make an informed decision.
My advice, for what its worth, would be:
- Get enough clutch to hold a full blown 24/18g package if that where you even think you might end up. Prices and driveability are not much if any different at all.
- You can get a lightweight dual mass flywheel from Aasco that alleviates using a longer eared release bearing...Quite a few of us have had them snap off due to the thinner lightweight flywheel. Also, some tuners will sell you the single mass lwfw but not send you or sell you a patch for the idle issue...unless you buy a complete tune from them. Remember, the single mass lwfw is prone to stalling issues. It will happen, no way around it unless you get a patch [I'd bet EPL would hook you up with something, but I also think they recommend against the single mass due to the above release bearing issues...but call them and ask...that way you hear from the source instead of reading about it from me...as I am not positive!]
-Strongly consider doing the GT2 modification when you do the clutch. Probably the single biggest issues people have with these cars that is clutch related involves the master and or slave cylinder. The GT2 mod fixes all those annoying problems.
Good luck and enjoy!
DrF,
Personally, I would retain the DMF, replace the pressure plate with a Sachs 999 and put in a new GT2 unsprung clutch disc. If you plan on 24/18G's then I would modify the pressure plate for additional clamp force before installation and use a Sachs Motorsports unsprung GT2 style, high friction disc.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
