Went to the 1/4 mile track
Old Oct 7, 2010 | 09:54 AM
TweakitTT's Avatar
TweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to behold
Ok, took my car to the track for the first time and looking for some advise from drag racers out there
Conditions: San Antonio Raceway, 70 degrees, clutch slipping through 1st gear.
1/4: ~13.1 secs
60ft: ~2.1 secs
ET Mph: ~110
I can understand the bad time due to the slipping clutch, but my friend driving a modded A3 had the same 60ft and ET Mph...but was hitting 12.7.
I think I am losing the most time on 1st to 2nd shift and 3rd-4th shift. Is there a specific technique on 1st to 2nd shift...redline shift or earlier? For 3rd to 4th If I stay on 3rd I will hit a little past redline...so I shift to 4th. Also on occasion I would lose grip in 2nd gear and the car will slide left...I didn't think traction would be an issue for awd?
What is the best technique? Or do I just start powershifting...lol.
Old Oct 7, 2010 | 10:01 AM
46and2's Avatar
46and2 is infamous around these parts
It sounds like you might be losing time with your shifting. Also, with AWD and some decent tires, you really should be able to cut lower 60' times.
With my 65 Mustang drag car, I would just stab the clutch, shift, and left go without lifting the throttle. I calculated my shift points based on the HP curve of the engine, transmission and rear end gearing, etc. My shift points were all before redline. I relied on the speed of my shifting and the rev limiter to keep me from grenading the engine. I personally would not do that on a car that isn't a dedicated track machine.
Old Oct 7, 2010 | 12:20 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
oh thats not to bad! watch my wideo below it may help.
http://www.streetfire.net/video/pors...388_713865.htm
i shift at 6500 so by the time im done shifting its closer to 6800 right still in the powerband. dont dump the clutch ride it out and do not powershift unless you feel like braking parts!
Speed Shift only!
Old Oct 7, 2010 | 06:32 PM
TweakitTT's Avatar
Nice run! I wish you had in car video so I can see how fast you are actually shifting. I have a feeling I am being too conservative on my shift. My concern is breaking my transmision so I make sure I am in gear before stomping on the gas again after each shift. When you shift are you still stabbing the clutch as fast as possible but letting off the gas pedal?
Speed Shift only!
Old Oct 7, 2010 | 06:58 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Talk to Powell, he can really give you some pointers.
Old Oct 7, 2010 | 07:11 PM
ttboost's Avatar
Most people have trouble with the 2-3 shift, not the 1-2 or 3-4. Also, if your clutch is slipping in first gear, it will REALLY be slipping the higher gears..which explains your low mph. Do you notice the car revving but not really accelerating that fast? Get a new clutch a go back...
Old Oct 7, 2010 | 07:25 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
forget the time for a minute, think of your trap speed which seems really low
Old Oct 7, 2010 | 08:31 PM
TweakitTT's Avatar
Agreed...actually surprised he hasn't chimed in yet since this is his forte
Is a good trap speed around 115 for stock turbo?
Its odd. I notice it slipping significantly in 1st gear...revs high but car doesn't really move. 2-4 "seem" to be ok. In order for me to move in 1st gear I have to launch <2k RPM then it seems to grab. 3k or over and it just revs. Previous owner probably used the car as a daily and slipped the clutch it 1st gear for a smooth start too many times. Clutch showed up on my PPI as needing replacement so I wasn't surprised.
After my clutch replacement I am probably going to dyno the car just to make sure there isn't any other issue.
Old Oct 7, 2010 | 09:46 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Speed Shift only!
Very good run PALETTE and excellent advise for us about shifting.
Old Oct 7, 2010 | 10:37 PM
TweakitTT's Avatar
Found this pretty good video on you tube. If I actually shifted as fast as the "speed" shifting in the video I would probably knock off .5 sec from my time. Time to go practice...
http://www.youtube.com/watch?v=Tv791ac2bmE
Old Oct 7, 2010 | 11:19 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
with decent weather, yes, 115mph would be good for a stock K16 car
COBB Tuning
Jan 1, 2025 09:02 AM
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
Apex Chase
Mar 28, 2016 02:00 PM
The Oss
Aug 24, 2015 08:19 PM
