TT lean past 1 BAR.
Old Oct 8, 2010 | 11:08 PM
P2P's Avatar
P2P
P2P is a jewel in the roughP2P is a jewel in the roughP2P is a jewel in the roughP2P is a jewel in the rough
Originally Posted by VividRacingTX
Did you ask Todd? How do you like the HKS?
Its a second to none ... more precise on controlling the boost ... no boost drop issue no spike issue .. comparing it to the greddy ? u r so mistake by comparing
Old Oct 8, 2010 | 11:09 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by Tim941NYC
Thank you, that worked. I got talked in to buying a Mac and now I need to relearn the use of a computer..
LOL! I've been there, done that, now I'm happily back to PCs.
Old Oct 8, 2010 | 11:10 PM
P2P's Avatar
P2P
Originally Posted by prodigymb
Get injectors - 5bar is really not enough to get the most out of 18Gs
For sure u r right .. it will be my next upgrade
Old Oct 9, 2010 | 08:16 AM
Tim941NYC's Avatar
Told them exactly what I do with a computer, none of the programs work on this and then they said I can split the the something and run half the way it is and the other half with the system needed to run my other programs.. No thanks, now I am trying to get a laptop that has a serial port..
Old Oct 9, 2010 | 09:41 AM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
can you log injector duty cycles?
a 16g at 1.2 bar will max a 5bar, sounds like you're out of injector
Old Oct 9, 2010 | 11:24 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
what version of durametric are you using?
we have seen high rpm AFR logging issue with the latest version.
Old Oct 9, 2010 | 02:18 PM
P2P's Avatar
P2P
i was data logging with the latest beta version .. i will do a data logging again with the previous one.
Old Oct 9, 2010 | 02:24 PM
P2P's Avatar
P2P
i was also thinking it might be a problem with a vacuum leak between the MAF and the turbo inlets. so i have air going in without being read by the MAF.
do you think i should check that before i do the test runs. would that kind of leak also have the effect of lowering idle do you think? the car idles at about 850 rpm. the tune on car is supposed to idle at 1100 rpm.
Old Oct 9, 2010 | 02:50 PM
My educated guess is yes, since fuel is metered by air flowing past MAF and if you have air coming in after the MAF it would not be taken into account and you could have lean fuel condition.
See if Todd can provide you with a MAFLess tune and then get rid off you MAF's.
Old Oct 9, 2010 | 03:26 PM
P2P's Avatar
P2P
I just did a run. the hks evc read boost at 1.05 bar but on the datalogging i got up to 1.13 bar. the injectors seem to be running at max cycle 27.8 ms at 6000rpm and 22.15 at 7000rpm.
so next up is fueling but im still worried about maf. I dont know how a mafless tune will hold up in weather where it goes up to 50 degrees C in the summer and 0 degrees at night in the winter. any thoughts?
Old Oct 9, 2010 | 03:46 PM
get the injectors and a tune.. maybe some decent ICs and leave it alone... Ive set up many guys like that and they love it.. maybe add the intake piping
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 9, 2010 | 04:18 PM
P2P's Avatar
P2P
Thumbs up
Will count on ur advice
Old Oct 9, 2010 | 04:41 PM
something is wrong if your your injection time is correct
120/6000*1000 = 20 max injector time but you are at 27.8
120/7000*1000 = 17.14 max injector time but you are at 22.15
either case you are way over 100%duty cycle.
You sure need to upgrade your fuel injectors.
Talk to Todd.K and seek his advice.
Old Oct 10, 2010 | 02:03 AM
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
malfess tune only ovaliable for 997 turbo not 996 turbo
bigger injectors is a MUST!!!!!!
Old Oct 10, 2010 | 06:31 AM
P2P's Avatar
P2P
I dunno.. i think i saw a 996 with mafless setup for some one here in 6speed but am not pretty sure.
