Dead Battery!
Old Mar 2, 2005 | 01:32 AM
Big Papa's Avatar
Big Papa is infamous around these parts
Dead Battery!
Battery is dead! Meter reads 11 volts, Does it sound like the altenator or could it be a loose belt. If its the Alt. how much does that usually cost to repair.
Old Mar 2, 2005 | 02:22 AM
pierre's Avatar
pierre is infamous around these parts
Mine died after about 3 years. My dealer replaced it, and told me it wasn't unusual. The alternator was fine, nothing to worry about.
Greetings,
--Pierre
Old Mar 2, 2005 | 02:41 AM
Big Papa's Avatar
battery
I replaced the battery and the volt metter still reads low, im sure thats its either the Alt. or the belts. How likely is it that a loose belt can cause the alt to not work.
Old Mar 2, 2005 | 02:17 PM
ar38070's Avatar
ar38070 is infamous around these parts
Does the car crank okay? If you run the car for an hour then shut down, does the car start okay?
Using a voltmeter what is the voltage at the battery? 13+ volts?
If all of the above are okay then it is probably the meter.
Old Mar 2, 2005 | 03:32 PM
djantlive's Avatar
It's probly the alternator since your voltage is low with the car running. Time for a new one.
vpr80
Mar 6, 2021 12:11 PM
airbusdrvr
Dec 27, 2015 07:43 PM
007 Vantage
Oct 8, 2015 08:35 PM
ek1
Bentley
Sep 26, 2015 11:54 PM
Zero911
Sep 24, 2015 06:33 PM
