Drag race stock tt Vs gt3
Going up against gt3 tomorrow,any pointers?As far as i see it,as long as I get first gear down right and into second it should be no problem.Would appreciate any input,even the obvious.Thanks in advance.
Originally posted by rockitman
If your TT is stock, you may have a problem, depending how long the race is....
It should be a close race...the GT3 will hook up before the TT
The bigger problem with the TT is bogging the engine or burning the clutch. I've gotten the best starts with 3500-4000 rpms and slipping clutch as you slowly add throttle. A few practice starts before the race may make a world of difference in your outcome.
I hope you will let us know how it turns out.
I think the Gt3 will beat you. The awd system is tough to launch well and just take such a beating. A rear wheel drive its nice and easy to launch and when you look traction you just let up off the gas alittle. My supra would kill evos in a drag race all day long, they jumped right off the line but I blew by them as soon as I went into 2nd gear. Alittle tip is to start letting the clutch out and start creeping up so you have the momentum coming off the line.
-Daniel
-Daniel
