PSM Engaging Prematurely
Old Mar 2, 2005 | 02:33 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Recently, my PSM has been engaging prematurely -- meaning, it engages during a rapid turn, even though I am not close to loosing traction. The dealer told me that my PSM system is working perfectly and the problem is "mechanical." They opined that the problem may have to do with my tires or brakes. I am using Brembo 14in brakes and MPSC tires (315/235). I can't be certain, but it may have started after I switched from 225s to 235s. Brembo is confident that the problem is unrelated to the brakes.
I also occassionally trip the PSM when I do a WOT sprint in fourth or fifth gear (this doesn't happen in lower gears, under less load).
Any thoughts would be appreciated.
Craig
Old Mar 2, 2005 | 02:47 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
Re: PSM Engaging Prematurely
Craig
a long time ago, it was said the slip angle needs to be reset (w/ Porsche system tester) when you widen the stance - front or rear.
Old Mar 2, 2005 | 02:51 PM
ColorChange's Avatar
ColorChange is infamous around these parts
Ben, can this be done??? I would be shocked (due to liability) but sure hope it can be.
Old Mar 2, 2005 | 03:36 PM
ben, lj's Avatar
Senior Member
i had it done on my c2
Old Mar 2, 2005 | 03:43 PM
sharkster's Avatar
I dunno if this helps or not but have somone check your cardon shaft... I bent the splines and it started doing that. Replaced the cardon shaft and it stopped...
Old Mar 2, 2005 | 04:09 PM
Craig's Avatar
Ben,
Did the dealer reset your "slip angle"? What is involved in this? Can a tuner with a PST II do it?
Sharky,
Forgive my ignorance, but what is a "cardon shaft"? Did the dealer replace it? Warranty? How much?
Thanks for the input.
Craig
Old Mar 2, 2005 | 04:10 PM
PMac's Avatar
PMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to behold
Are your rolling diameters front to back within a couple of percent?
Shot in the dark, but an easy fix if that's the problem.
Old Mar 2, 2005 | 04:15 PM
Craig's Avatar
I have no idea. Does anyone know how to calculate this? I have 235 MPSCs on the fronts (18x8.5) and 315 MPSCs in the rear (18x11.5).
Thanks,
Craig
Old Mar 2, 2005 | 04:22 PM
Craig's Avatar
I just got off the phone with Tire Rack:
MPSC 235/40/18 does 819 revolutions per mile.
MPSC 315/30/18 does 815 revolutions per mile.
That variation is well within acceptable limits and does not appear to be the problem.
Craig
Old Mar 2, 2005 | 04:35 PM
PMac's Avatar
Craig
Beat me to it. The quest continues.
Old Mar 2, 2005 | 04:56 PM
ben, lj's Avatar
Senior Member
Ben,
yep, it was a dealer. i'm pretty sure they just plug it into the PST to reset it. there is a thing for it in the menu.
Old Mar 2, 2005 | 04:57 PM
JakeMate's Avatar
JakeMate is infamous around these parts
I've had two instances where my PSM would come on prematurely. First, there's a section on a canyon road near my home that has an off camber turn over a crest kinda thing. It almost always goes off and scares the **** outta me every time.
Second, I just put new S-02A rear tires on over the weekend. I have P Zero fronts that are about 60% gone. While braking on a turning off ramp, PSM came on prematurely also. It hasn't happened since but I've just been commuting without driving in anger.
Its pretty sensitive.
randalldahme
Feb 19, 2016 03:56 PM
agentsmurf
Cayenne 955/957
Oct 17, 2015 02:10 AM
007 Vantage
Oct 8, 2015 08:35 PM
TOGWT
Detailing
Sep 26, 2015 08:28 AM
PelicanParts.com
Sep 25, 2015 03:17 PM
