How can I stop the wing....?
Old Mar 9, 2005 | 12:33 AM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
.... from moving up and down without causing a warning light?
Thanks for your help.
Old Mar 9, 2005 | 04:06 AM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
I'm getting the wing lift failure light too
Hey yogi bear, are u going to join us in Belden Alley this thurs nite?
Old Mar 9, 2005 | 07:19 AM
PorschePhd's Avatar
Take and cut the blue/green wire. Tape the ends off or pull it out of the harness. Next splice the green/yellow wire with the gray/brown wire. This should disable the light and allow the unit to think the tail is present and working. It is just a bypass.
Old Mar 9, 2005 | 11:28 PM
BlackBear's Avatar
I have a hot date on Thursday... Maybe next time.
Old Mar 9, 2005 | 11:29 PM
BlackBear's Avatar
Thank you for your help. I'll try it tonight.
Old Mar 9, 2005 | 11:33 PM
Senior Member
Man, I must be a loser going to dinner on a thursday with a bunch of 6spdrs.
Old Mar 10, 2005 | 12:47 AM
BlackBear's Avatar
Stephen,
I just cut the blue/green wire and the wing is now fixed in position.
I located the thick green/yellow wire but could not find the gray/brown wire.
Here are the wires I have:
brown/red
thick brown
thin brown
red/blue
black/thick
black/thin
black/brown
blue
gray
thanks.
Old Mar 10, 2005 | 12:55 AM
sharkster's Avatar
How 'bout the May 7th meet/drive?
https://www.6speedonline.com/forums/...threadid=22905
Old Mar 10, 2005 | 09:40 AM
TT Surgeon's Avatar
I believe the GT2 wiring harness will fix your problem.
Old Mar 10, 2005 | 11:58 AM
PorschePhd's Avatar
I checked again and that is right. Pull the plug at the tail over in the right side of the motor. Look at the plug going to the tail, not the body. You will have two gray wires, one with a brown stripe and one without. You also should have yellow/green. Those go together. The other side of the harness is different so look at the tail portion.
Old Mar 10, 2005 | 05:19 PM
BlackBear's Avatar
Sthephen,
I looked on the wing end of the wires last night and will pull the plug tonight.
Thanks again.
Porsche246
Oct 10, 2015 04:02 PM
jab23
Cayenne 958
Oct 2, 2015 08:40 AM
drkbrent
Oct 1, 2015 07:30 AM
