Diverter Valves
Old Dec 6, 2010 | 03:40 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
This is very useful info, thank you!
I think this should go to the 996TT knowledge thread....
Old Dec 12, 2010 | 11:07 PM
GMendoza's Avatar
GMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of light
Well, I purchased a pair of 710N valves for $38 each and replaced my working 710A/108 valves. Both valves look identical but the 710N has a noticeably stronger spring and seals better. Now for my results
Before my car would spike to 1 bar then fall off to .9 bar from 4.5k rpm to redline in all grears. Now it still tappers down to .9 bar in 1st-3rd gear but now it holds 1 bar in 4th gear and above all the way to redline. Also, there seems to be less lag between shifts. overall, im satisfied with the improvement for less than $100
Old Dec 13, 2010 | 11:52 AM
eglivincent's Avatar
eglivincent is infamous around these parts
how hard is the install?
Old Dec 13, 2010 | 12:25 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I installed some Forge's on mine a few years back and did not see a difference but for less than $200 what do you expect.
Old Dec 13, 2010 | 03:13 PM
GMendoza's Avatar
Using this thread as a guide and AWE's instructions, it wasn't bad; took a little over an hour.
https://www.6speedonline.com/forums/...narrative.html
Old Mar 19, 2018 | 10:08 PM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
Absolute MUST...for tuned Turbo!
My 710A was bleeding boost pressure at higher rpms, resulting in P0299 underboost DTC. Once the 710N was installed.... it pulls like a freight train once again.
Old Mar 20, 2018 | 04:31 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
How much was the valve.
Old Mar 20, 2018 | 07:47 PM
I got the Professional Parts Sweden 710N. They are made to Bosch Spec, for all Saab, VW and Audi cars.
White991TT
Mar 8, 2016 06:01 AM
sdg1871
Nov 22, 2015 07:27 PM
flewis763
Oct 4, 2015 04:14 PM
