must have suspension mods???
Old Jan 13, 2011 | 09:03 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
I would still do a rear sway bar.
Old Jan 14, 2011 | 09:11 AM
I did both front and rear H&R sway bars in comination to Champion/H&R springs I already had. Sway bars definetly improve the feel and stability during cornering, they reduced body roll. I want to get a set of coilover next and do the bushings.
#TeamAIM
Old Jan 14, 2011 | 10:50 AM
TekNiC3's Avatar
TekNiC3 is infamous around these partsTekNiC3 is infamous around these parts
Originally Posted by snopdog911
so you dont need sways with x73.
I just installed the X73 with H&R sway bars (front and rear).
I can say the handling feels amazing with this set up.
Old Jan 14, 2011 | 10:58 AM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
I was thinking of doing the X73 mod as well and since we are both in SJ maybe I can check yours out sometime.
Old Jan 17, 2011 | 03:24 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
The H&R sways aren't expensive and are adjustable, so they will keep you occupied adjusting something at the track Most can get away with the the H&R rear sway.
Old Jan 17, 2011 | 07:47 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Originally Posted by Duane996tt
X73 in the long run is the easiest solution (no guess work). Otherwise plan on coil overs (PSS10 are a good street/ light track option), sway bars, adjustable rear upper control arms, adjustable rear toe link, rear drop links. Install with alignment and corner balance about $5k.
Yep.
I went JIC 8/12 kg fr/rear. AP control arms, links, H and R front and rear sways and a gt2 stance with a corner blanace.
Now the weak link is the human....um, that was the case before too really.
Jeff
Old Jan 17, 2011 | 11:13 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Do you track your car at all?? If so have you experienced before and after the X73 was installed? I already have the sway bars looking at options thanks.
Old Jan 17, 2011 | 12:20 PM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
...cant believe with all the things you have done to your car coilovers aren't one of them prod, what gives?!!?!
Old Jan 17, 2011 | 06:28 PM
snopdog911's Avatar
snopdog911 is infamous around these parts
would you say the x73 is harsher than JIC for daily driving on crap roads?
or KW V3 any better?
Old Jan 18, 2011 | 11:09 PM
TekNiC3's Avatar
Sure. Just shoot over a PM when you want to check it out.
Old Jan 18, 2011 | 11:10 PM
TekNiC3's Avatar
Can't speak for those two systems, but on the PSS9, the X73 feels like the dampers are set at 2-3.
Old Jan 24, 2011 | 04:28 PM
sunir's Avatar
I'd like to try to take a ride in an X73 car on our roads in the MD/DC/VA metropolitan area before thinking about this suspension - anyone have an X73 car here?
I also like the H&R bars, have used them on other cars and they offer good quality and value and perform well for a non full race item.
Anyone tried H&R coilovers, they are only height adj with threaded perches but they are pre-valved and non adj damping - figure may go well with a set if their bars...
Old Jan 24, 2011 | 04:43 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
+1 on what TT Surgeon and Duane said, the X73 is very well balanced, perfect ride height and ride quality for what you're looking for. I've been on mine for over 5 years and don't have a single complaint and I drive the hell out of my car. The included transmission mount and engine mounts are nice too :-) No need for sways, links or corner balancing, Porsche did all the work for you.
riverflyer
Sep 1, 2015 04:22 PM
orbelo
Aug 30, 2015 12:26 PM
tkeck3
Aug 25, 2015 02:52 PM
Zero911
Aug 24, 2015 06:51 PM
TrackOne
Aug 20, 2015 12:56 PM
