I need help getting exhaust off, the turbo bolts seems to either a 3/8" or 9mm, the
Old Dec 11, 2010 | 12:00 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
upper bolt seems to be bigger?? But all I can get on it is a tiny open end wrench, I'm afraid of stripping it, they are very tight!! Sprayed it w/PB blaster and let it sit over night, a socket will fit but no room to attach the wrench to the socket head. Also, the "quick connect", for the O2 sensors I can easily reach from top of engine bay, one of the 2 comes off easy, other doesn't seem to have a release clip?? Any help would be greatly appreciated, Thanks, Scott
Old Dec 11, 2010 | 01:36 PM
Tim941NYC's Avatar
The bolts on each flange are all the same size. One of the O2 clips is the same as the MAF the other you lift the gray tab and it opens its self up.
Old Dec 11, 2010 | 02:29 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
I thought they were 10mm nuts. I found for the top nuts you have to use a small box end wrench to start and it will only move about 1/4 to 1/3 a turn at a time. After a few complete turns you can get a short socket on it if you connect that to a universal joint and the uni on a small head socket wrench. The bottoms are a little easier to get to.
It just takes time so be patient.
Old Dec 11, 2010 | 06:22 PM
No SubstiTTute's Avatar
No SubstiTTute is infamous around these parts
As mentioned above, all 4 bolts holding the exhaust to the turbos have the same size. You need a 13mm wrench.
A curved box end wrench helps for the top nuts. Here is a pic of the 13mm wrenches that are supplied with the Europipe exhaust. The small section of metal tubing in the picture slides over the end of the one ended box end wrench to gain more leverage and to ease the placement of the wrench.
Mine were rusted on pretty good too. Lots of penetrating oil and patience. Good luck.. Hope this helps.
Old Dec 11, 2010 | 06:51 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Nothing is American measurement on these cars. If something seems to be closer to 3/8" on the exhaust, then that's because of the inherent corrosion that happens on all exhaust parts due to time.
Old Dec 11, 2010 | 07:02 PM
Sorry, it is a 13mm. If you're having to push pretty hard just be steady. Also use a open palm w/ the wrench directly in the middle of your palm right above the wrist.
That way if it slips off or releases quickly you won't smash your fingers.
You can also use a dead blow hammer to give the wrench a sharp hit. Again just have patience and be steady w/ pressure.
Old Dec 11, 2010 | 07:03 PM
mdd's Avatar
mdd
mdd is infamous around these parts
All the nuts are easy to reach with a crowfoot wrench and a really long extension. This approach also lets you torque them properly when you put it back together.
A cheap set from Harbor Freight works just fine for occasional use stuff like this.
http://www.harborfreight.com/7-piece...set-94427.html
Old Dec 11, 2010 | 08:52 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
Trust me- Gear Wrench. I can do my exhaust in 30 minutes on and off.
Old Dec 12, 2010 | 11:29 AM
ard's Avatar
ard
Like that in a 6-point box....
Old Dec 12, 2010 | 10:25 PM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
+1 on the ratcheting box end
BlackMarketRacing
Dec 3, 2015 10:46 AM
RS GT3 RS
Sep 24, 2015 09:27 PM
Lucid Moment
Aug 20, 2015 02:22 PM
cab83_750
Aug 19, 2015 12:37 PM
oddjob142
Aug 19, 2015 12:27 PM
