Turbo cutting out
Old Dec 30, 2010 | 10:22 AM
TTS's Avatar
TTS
TTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of light
Turbo cutting out
On full acceleration I have had my turbo cut out on me and lose almost all power. The check engine light comes on. After stopping and restarting the engine, all is good again. The check engine light goes off after another 2 uneventful starts. Anyone with this issue?
Old Dec 30, 2010 | 10:29 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
limp mode - misfire, boost leak, bad maf. Read the codes and all will be revealed!
durametric
Old Dec 30, 2010 | 11:24 AM
XLR82XS's Avatar
durametric
Exactly.
Old Nov 30, 2012 | 12:05 AM
googler2's Avatar
googler2 is infamous around these parts
Hi TTS, did you get this issue resolved? My 996 turbo now has just now developed same issue. Thanks
Old Nov 30, 2012 | 07:55 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
Def a Maf issue
Old Nov 30, 2012 | 09:24 PM
jqhayden's Avatar
jqhayden is infamous around these parts
Had the same problem. Swap Maf. Easy to do, except paying $300 for a small piece of plastic.
Old Dec 1, 2012 | 06:31 AM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
Sorry, I'm new to the 996 but on other turbo cars that sounds like fuel cut. You're suggesting it's the MAF, if so the ECU can't understand or is getting incorrect readings from the maf and is going into safety.
Typically with a hotwire MAF you can pull them and spray with an electrical contact cleaner. If it's debris that's causing the issue, this could help extend the life of the MAF. I'd try cleaning (nothing to lose) before replacing.
http://www.halfords.com/webapp/wcs/s...egoryId_255223
If you want to try, ensure you're using a product like this. DO NOT use brake clean, windex, water, or any other bologna. Isopropyl alcohol also works if you can find it.
Regards,
Old Dec 9, 2012 | 02:39 PM
googler2's Avatar
Replaced MAF, problem still exists, any other suggestions? Thanks
Old Dec 9, 2012 | 05:22 PM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
Were you able to scan the codes googler2? This would likely help to diagnose. Perhaps you have a buddy with some licenses available on a Durametric if you don't have one?
Old Dec 9, 2012 | 05:40 PM
Turbo Singh's Avatar
Turbo Singh is infamous around these parts
+1 get the codes
I had the same loss of power problem but with no lights. Turned out to be a U shaped hose in the fuel pump unit. Under heavy throttle it would just dump fuel back into the tank.
Apparently its a common issue.
Good Luck!
Old Dec 9, 2012 | 09:27 PM
ard's Avatar
ard
Generally there are pretty smart folks that scan this forum with significant knowledge.
HOWEVER, when they read a thread where someone says "I got a CEL light", and people say "Read the codes and post". I am of the opinion that the most knowledgeable members will not repeat the advice AND they will not venture an opinion until the OP does that mandatory first step. READ THE CODES. dont start replacing parts.
Read
The
Codes
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
magoochi
Aug 23, 2015 05:54 PM
