Engine removal thread....
Old Jan 2, 2011 | 06:39 PM
M3EvoBR's Avatar
M3EvoBR has much to be proud ofM3EvoBR has much to be proud ofM3EvoBR has much to be proud ofM3EvoBR has much to be proud ofM3EvoBR has much to be proud ofM3EvoBR has much to be proud ofM3EvoBR has much to be proud ofM3EvoBR has much to be proud ofM3EvoBR has much to be proud of
oh ok, tks for the info, but I just realized that his car is stock ... weird
Old Jan 2, 2011 | 06:40 PM
Tim941NYC's Avatar
Originally Posted by M3EvoBR
which would be the RPM numbers on those overrev 1 and 2 ?
I don't think the durametric will tell you that. I think it just tells you the number of times over the limit not the length of time or rpm's hit. You need the pwis for that.
Old Jan 2, 2011 | 06:43 PM
Tim941NYC's Avatar
stock for the second and third owner. unless the first owner just drove every where in first gear..
Old Jan 2, 2011 | 06:48 PM
M3EvoBR's Avatar
Originally Posted by tim941nyc
stock for the second and third owner. Unless the first owner just drove every where in first gear..
lol.
Old Jan 2, 2011 | 07:02 PM
Tim941NYC's Avatar
I was checking their website and saw the kits that I got ...
#B9612K-Plus
and I got another case with a few tools, that I can't tell for sure.
they were helpful and professional on the phone, and I got everything next day as I'm also in Florida.
That part number is for the N/A motor. Those tools do not work on the tt motor. I only found the timing plates and tools needed to hold the cam's for the turbo motor on their site. You will still need the tools for the install of the cylinders
Old Jan 2, 2011 | 07:04 PM
jpflip's Avatar
Thats a picture of the cam timing tool ....
Old Jan 2, 2011 | 07:10 PM
Tim941NYC's Avatar
yes sir that's it. You still need the piston ring retaining clip that lets you install the center piston.
jpflip's Avatar
Other tool needed are on these pics, piston circlip tool, cylinder press toll, piston ring tool, also the handle to move the cam can be useful.... Take a good look Tim and let us know!!!
Old Jan 2, 2011 | 07:14 PM
Tim941NYC's Avatar
Yes sir. Looks like the pics from IA site
Old Jan 2, 2011 | 07:16 PM
jpflip's Avatar
Yes sir! I looked at it so often I memorized it to be ready for the big day
Old Jan 2, 2011 | 07:21 PM
Tim941NYC's Avatar
HAHA! Nice. If I can help you with anything let me know. If you are going in the case will you do rods, gt3rs oil pump, and head studs?
Old Jan 2, 2011 | 07:30 PM
jpflip's Avatar
Tim, you are talking to a person that got very limited financial possibilities....
But I would like to be able to install a gt3 intermediate shaft... You seems to be very knowledgeable in the TT engines. Did you ever done deep mechanic works on your TT or engine overhaul?
Old Jan 2, 2011 | 07:41 PM
Tim941NYC's Avatar
Yes I have. I have some things laying around.. My car has made 10.xx second pass at 139.9 mph with a 60ft of 1.88. I was making 700 and change on the wheels then. I posted a time slip. I got kicked out the last time with a very low 10 second pass that I had to lift in 2nd gear and still trapped a 145.xx I was told my numbers but no slip do to the fact that I do not have a cage to run those times and the tracks insurance.
Old Jan 2, 2011 | 07:57 PM
M3EvoBR's Avatar
Def a lot more than what I got, I'll check everything tomorrow ... tks for the advice.
Old Jan 3, 2011 | 06:08 AM
jpflip's Avatar
Ouch! Amazing numbers. You can be sure I will contact you If I need more info before I start this challenge
Jul 29, 2019 11:13 AM
Sep 1, 2015 03:16 PM
The Oss
Aug 24, 2015 08:19 PM
Aug 20, 2015 12:17 PM
