100% Methanol on race file
I'm comparing it with VP109 since my race file is tuned for VP109. I do not think it is fair to compare any gas with C16. It's something else. And as I said, until the certain boost levels, yes it does give the same protection. But after somewhere, it's still good, but not as good. I have tried and seen this with my car myself. But it's still the best alternative to the race fuel.
Ya, we've gone round and round and round on this topic. Some people say it's not as good as race gas. Some say it is. Point is (as I stated above), it's "pretty much the same".
Also remember that the term "race gas" can mean anything from 98 octane to C16 to Fuel Alcohol, and I have no idea which level of race gas you're comparing it to. If pump/meth provides the same protection as 100 octane (which it certainly does) or even 104, then yes, it would very true that it is "just as good" as race gas.
Me? I'd never use it. I don't trust the systems enough.
I would. Very high quality kit and very reliable. I have the older HSF-1 and have had not 1 problem with it. The newer kits cost more, but are more "plug and play". Even though my meth tune isn't really aggressive, I test my safety's once in a while. Just let it run out. If the meth gets too low in the tank, wastegate pressure. If the line breaks, wastegate pressure. As far as install, I did my own install. Took me about 6-7 hours and I had never worked on my Pcar before. I think a reputable shop could do it in 5-6 hours or so, not including tuning. You have to decide where to put the tank and how big a tank to install. The Aquamist kit does NOT come with a tank. Most people run a 1-1/2 gal tank, you can get for like $50.
I might need to find another shop in L.A to do it. I really like the failsafes. Back to AZ for a retune as soon as I install it.
Yes for sure! There are mutiple fail safes u can buy. My tuning program as an extra meth controller seperate unit that aslo changes the tune to conservative timing and afr as well.
Ofcourse fail safes are always a good idea. Like I said before the resaon I prefer some water mixed in is I found I get much lower boost temps and less prone to knock compared to 100%.
You are correct when you noticed higher timing ability on water than methane injection. The danger with high percentages of methane (tuned for usage above 50% meth) is if the meth goes out the motor goes lean and you will lose your motor. The same thing happens when you mix fuel in your tank. You usually never know what you have.
The EBC doesn't have any control over the meth system. If your not tuned for Meth, it's hard to say if your wastegate will be too much?
I know the EBC has no control of the meth system, I guess what I was asking was this past weekend with PCA I ran out of mix on the last session, I run the track with the boost controler off, would running the car (that has a program for 50/50 mix) without any mix limiting the boost to 1 bar do any harm? I ran the car easier knowing I was out of mix.
You probably weren't running the most efficiently, but looks like you're OK at that boost level.
You may be correct for your car. Did you dyno this? 30 hp sounds like alot just by increasing meth %. Where all the mods the same with similar temps outside? On my car with 100% meth I saw knock come earlier with much higher boost temps and can't advance as much timing or run as high boost as with a water mix.
This was all done on the same Mustang dyno on the same day. We started with 50/50 and got to the max boost and timing it would take. We then converted to 100% and kept going. I picked up 40whp with 50/50 and about 70whp with 100% meth from my baseline, with all of the same mods, which is 18g's, 58lb injectors, 5bar, FVD exhaust and an Aquamist kit. Stock airbox, stock piping and stock IC's. It's all in the tuning. Apparently, my car runs very well for the mods it has. Doing piping and IC's now. Will likely post a separate thread with results whenever it happens. It will be a while.
It will be cool to see what you put down with upgraded piping and ic they make a big difference especially if the stockers aren't great. I upgraded my ic to an ETS and picked up about 2psi from increased efficiency. I tested before and after at just wastegate spring pressure.
BlackMarketRacing
Dec 3, 2015 10:46 AM
