Spark Plugs for 1.2bar
Old Jan 11, 2011 | 05:38 PM
sunir's Avatar
So more boost = use step colder plugs got it...
but looks like the jury is still out on widen the gap or tighten the gap, two camps on this one...any more thoughts
Old Jan 11, 2011 | 05:44 PM
ttboost's Avatar
Close it up with higher boost.
Old Jan 11, 2011 | 08:00 PM
johnspeed's Avatar
IF you had Higher energy coils then it would be benifical,as the reasons were stated above,to open the gaps.....As any manufacter of high out put coils would do so,thats what you use them for.......A smaller gap is harder to blow out under pressue BUT it does not expose more flame for a better burn/explosion.....All this is basic 101 performance stuff...So,if confused,leave it at stock gap,,,Anyways a 'couple' of thousandths is not that much difference because there is usually a range to be in before you do loose efficiency of the gap .........Just my info to try to help out........
Old Jan 11, 2011 | 08:08 PM
ttboost's Avatar
I was just posting my experience. At 1.2-1.3bar, with stock gap ( .030-.032), I had misfires with 997 coils, which I believe are the updated coils now for the 996. All things being equal, my car runs great with a .026 gap.
Old Jan 11, 2011 | 08:59 PM
johnspeed's Avatar
I do not know how the 997 coils are as compared to the 996 ones with voltage energy??All I can say,is that my installer put those above plugs in that EPL sent me and they said they were stock gapped.Now with the cold weather, low 30's temp I am hitting 1.3 bars in 3rd right away and 1.4 bars right away in 4th with no misses........I will keep my fingers crossed,,,,,lol.......Have a good night guys
Old Jun 18, 2012 | 09:57 AM
vshugo996's Avatar
vshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to behold
Originally Posted by Robin@EPL
We like the NGK BKR7E... use it almost exclusively.
Hi Robin,
The NGK plug is BKR7EIX-11 (iridium)?
This NGK plugs are similar to Denso IK22.
Old Jul 26, 2012 | 10:23 AM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
Originally Posted by vshugo996
Hi Robin,
The NGK BKR7EIX plugs are great plugs for a 911 turbo with some mods. Gap it at around the .026 or .028 range as per normal and you should be good to go.
That is what is in my car as of now and coincidentally that is also what is in my supercharged Russian aiplane for the last 4 years.
Old Jul 26, 2012 | 10:40 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
we are useing NGK spark plugs BKR7EIX (2667) from stage 1 to stage 4
smooth and running good
Old Jul 26, 2012 | 12:27 PM
PICS of such creature ASAP !!!!
#TeamAIM
Old Jul 26, 2012 | 06:49 PM
BUTZI996TT's Avatar
BUTZI996TT is a jewel in the roughBUTZI996TT is a jewel in the roughBUTZI996TT is a jewel in the rough
NGK BKR7E gapped to .025 have served me well at 1.4 bar. The car runs smooth as butter and is fast/strong as can be. At $2 a plug you cannot beat them. Part #4644 at Advanced Auto.
Old Jul 26, 2012 | 07:33 PM
ysfg35's Avatar
which tune you are running ??
Old Jul 26, 2012 | 10:50 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
I'm on BKR7EIX now and just started getting some misfire after 3000miles....
I'm thinking the plugs are the culprit. Just changed coilpacks at the same time to brand new ones....
Old Jul 27, 2012 | 06:26 AM
BUTZI996TT's Avatar
EPL tune
Old Jul 27, 2012 | 06:30 AM
ysfg35's Avatar
EPL tune
its weired that EPL recommended them for you !!!!
Old Jul 27, 2012 | 08:48 AM
BUTZI996TT's Avatar
They didn't. While I believe they use the BRK7E's, I have always used them in turbo cars in the past (VR6 Turbo, S4's, Etc.) They are an all around great, effective, cheap plug that you can buy almost anywhere.
