Anti-seize paste on the spark plugs?
Old Feb 1, 2011 | 08:51 PM
code7rpd's Avatar
code7rpd has a spectacular aura aboutcode7rpd has a spectacular aura about
I'm getting ready to change the plugs and I know for the aircooled Porsches anti-seize was not recommended on the threads. Should I use or not on the 996TT?
Old Feb 2, 2011 | 03:39 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
it is not nessesary to use a anti seize paste
Old Feb 2, 2011 | 06:05 AM
mmm635's Avatar
mmm635 is infamous around these partsmmm635 is infamous around these parts
Anti-seize should never be used on threads for the plug. It is better to just put a light coat of motor oil on the thread and that is all you need. If the anti-seize just so happens to get on the tip of the plug, you will then have problems.
Also, it is easier to to unplug each of the oils before you take them out of the hole. If you leave them connected and try to maneuver them around to get them out of the way, you can easily stress the out and could result in breakage. If you press on the rubber part, you will then feel the clip that holds it down and it will easily release the coil pack.
Old Feb 2, 2011 | 08:59 AM
code7rpd's Avatar
Good info - thanks!
Old Jun 11, 2011 | 11:46 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
Being a contrarian I put anti-seize on spark plugs and have for years. I understand fully the negatives regarding getting it near the electrodes and into the combustion chamber. A very light coat will make for easy removal and help protect threads in the head against galling, cross threading and other damage. I got into the habit working on motorcycles for a living, most with aluminum heads and experiencing spark plug seizure numerous times and removing aluminum head material along with the spark plugs on occasion. I feel protection of the threads is more important than risking anti-seize in the motor.
Old Jun 12, 2011 | 12:14 AM
ard's Avatar
ard
I put anti-seize on the plugs both times I've changed them.
VERY thin, and keep it away from the sealing ring- I put a thin 'swipe' around the threads towards the electrode end, then use a clean shop towel to wipe it around and almost off- just a thin code in the threads. Keep it off the electrode itself and off the insulator as well.
This was confirmed by Kevin at UMW,
Old Jun 12, 2011 | 12:15 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Yes if you're careful with the stuff.
Old Jun 12, 2011 | 01:53 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
+1
I do exactly the same and always have.
Old Jun 12, 2011 | 08:28 AM
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
Add me this list... regarding the usage
Old Jun 12, 2011 | 10:19 AM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
Fully agree with this as well, just be careful when you do it.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
NC 996TT
Mar 23, 2023 06:19 AM
BLKMGK
Sep 19, 2015 03:51 PM
gadgetman
Sep 10, 2015 03:29 PM
