Carrera GT Key Head- didn't come with code tag...
Old Feb 16, 2011 | 07:24 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
Bought a new Carrera GT key head from Sunset because my key head is not working (tried replacing the battery, no dice).
I understand new key heads come with a code tag attached used to program the car/key- this one did not...
Ideas on how I can obtain the key code? I can't imagine the Carrera GT keys don't come with codes for programming. Dealer was pretty clueless...
Old Feb 16, 2011 | 07:55 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
Did it actually come with guts or is it just the cover?
Old Feb 16, 2011 | 07:56 PM
PAULUNM's Avatar
Yes, came with the guts.
Old Feb 17, 2011 | 07:31 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Did you take the little "pill" out of your existing key and put in into the new one?
Tom
Old Feb 17, 2011 | 07:32 PM
PAULUNM's Avatar
Originally Posted by Elegant Performance
The little "pill" is that the immobilized picks up so you can start the car. You have to switch it from the old keyhead so you can start the car. Than you need to pogram the remote so you can open the doors and trunk. PM me if you want the ptogramming sequence and I'll look it up for you.
Sunset is telling me the CGT keys don't come with the codes, as they are programmed differently.
Can anyone confirm that they have bought a CGT key and it's included the code?
Old Feb 18, 2011 | 07:31 AM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
The attached should clear things up for you. I couldn't find the Carrera GT workshop manual for free but you can Google it up and get it for about $15, if you're really curious as to how it's done on that car.
File Type: pdf
File Type: pdf
Old Feb 18, 2011 | 08:03 AM
PAULUNM's Avatar
That's awesome, thank you.
Am in interpreting correctly that you CAN determine the key code for a new key without the key tag?
Old Feb 18, 2011 | 08:09 AM
tvurt's Avatar
I think you are over thinking this. I converted to the 997 key head, by taking ALL of the guts out of the 996 head. There was no "code" needed as you are moving the parts that contain the "code". This is a really simple move, like 10 mins. Did you put the immobilize(er) "pill" in the new key? It will not start with it.
Here are the instructions from Suncoast: http://www.suncoastparts.com/category/gtdesignkey.html
Old Feb 18, 2011 | 08:16 AM
adam699's Avatar
Yes and no. But it's more complicated. There is the way the dealer does it and a way locksmiths do it.
In your case, you need to swap the guts from the old key to the new 2 button housing. As the Carrera GT guts will not work.
Old Feb 18, 2011 | 08:17 AM
adam699's Avatar
I think the deal is , the way I understand it, that his remote stopped working so he thought he can kill 2 birds with one stone by getting the GT key with the guts.
Old Feb 18, 2011 | 08:25 AM
tvurt's Avatar
Ah that makes sense. Get one of the old keys working first and this is simple.
Old Feb 20, 2011 | 04:53 PM
serge1ny's Avatar
serge1ny is infamous around these parts
I bought a GT head from sunset and it came with the tag !
Mine came with the tag !
see picture..
Old Feb 20, 2011 | 06:02 PM
PAULUNM's Avatar
see picture..
Perfect- very helpful.
To update everyone- Sunset is ordering another key for me- hopefully this one comes with the tag...
Old Feb 20, 2011 | 06:47 PM
marksf123's Avatar
marksf123 has much to be proud ofmarksf123 has much to be proud ofmarksf123 has much to be proud ofmarksf123 has much to be proud ofmarksf123 has much to be proud ofmarksf123 has much to be proud ofmarksf123 has much to be proud ofmarksf123 has much to be proud of
I have a bad key - can i replace it with this type of key? Does it come with the guts and then i have to get it programmed? How much is the programming?
Old Feb 20, 2011 | 07:32 PM
PAULUNM's Avatar
My understanding is yes- the CGT key can be programmed for a 996. When my CGT key (with guts) showed up without the key tag... I was a little worried.
A dealer charges a lot to program... Like 3 hours. My indy mechanic has the ability to program a key in 15 minutes, but he needs the key code and vehicle code to do it.
Jul 29, 2019 11:13 AM
away
Sep 4, 2015 12:30 PM
cordsig79
Cayenne 955/957
Aug 28, 2015 12:36 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
